Microsoft Surface Book 2 15" Rear Camera Replacement
    1. Microsoft Surface Book 2 15" Rear Camera Replacement, Motherboard: step 1, image 1 of 1
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Rear Camera Replacement: step 2, image 1 of 2 Microsoft Surface Book 2 15" Rear Camera Replacement: step 2, image 2 of 2
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      Ask FixBot
    3. Microsoft Surface Book 2 15" Rear Camera Replacement: step 3, image 1 of 1
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      Ask FixBot
    4. Microsoft Surface Book 2 15" Rear Camera Replacement: step 4, image 1 of 1
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      Ask FixBot
    5. Microsoft Surface Book 2 15" Rear Camera Replacement: step 5, image 1 of 2 Microsoft Surface Book 2 15" Rear Camera Replacement: step 5, image 2 of 2
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      Ask FixBot
    6. Microsoft Surface Book 2 15" Rear Camera Replacement: step 6, image 1 of 2 Microsoft Surface Book 2 15" Rear Camera Replacement: step 6, image 2 of 2
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      Ask FixBot
    7. Microsoft Surface Book 2 15" Rear Camera Replacement: step 7, image 1 of 1
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      Ask FixBot
    1. Microsoft Surface Book 2 15" Rear Camera Replacement, Front Camera: step 8, image 1 of 1
      • After lifting the motherboard, locate the two cameras near the center of the motherboard.
      • Unplug front camera (right side) from the motherboard (lift carefully).
      Ask FixBot
    1. Microsoft Surface Book 2 15" Rear Camera Replacement, Rear Camera: step 9, image 1 of 1
      • In the top left-hand corner of the tablet is where the camera sits.
      • Unscrew the T3 torx screw.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Rear Camera Replacement: step 10, image 1 of 1
      • Unplug the camera from the connector and remove.
      Ask FixBot
Colton Almeida
172 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 682
