Microsoft Surface Book 2 15" Motherboard Replacement
    1. Microsoft Surface Book 2 15" Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Motherboard Replacement: step 2, image 1 of 2 Microsoft Surface Book 2 15" Motherboard Replacement: step 2, image 2 of 2
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      Ask FixBot
    3. Microsoft Surface Book 2 15" Motherboard Replacement: step 3, image 1 of 1
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      Ask FixBot
    4. Microsoft Surface Book 2 15" Motherboard Replacement: step 4, image 1 of 1
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      Ask FixBot
    5. Microsoft Surface Book 2 15" Motherboard Replacement: step 5, image 1 of 2 Microsoft Surface Book 2 15" Motherboard Replacement: step 5, image 2 of 2
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      Ask FixBot
    6. Microsoft Surface Book 2 15" Motherboard Replacement: step 6, image 1 of 2 Microsoft Surface Book 2 15" Motherboard Replacement: step 6, image 2 of 2
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      Ask FixBot
    7. Microsoft Surface Book 2 15" Motherboard Replacement: step 7, image 1 of 1
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure to add some new adhesive to the screen to keep it in place.
Ryan Picewick
537 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 119
All Time: 5,286
