Microsoft Surface Book 2 15" Heat Sink Replacement
    1. Microsoft Surface Book 2 15" Heat Sink Replacement, Motherboard: step 1, image 1 of 1
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Heat Sink Replacement: step 2, image 1 of 2 Microsoft Surface Book 2 15" Heat Sink Replacement: step 2, image 2 of 2
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      Ask FixBot
    3. Microsoft Surface Book 2 15" Heat Sink Replacement: step 3, image 1 of 1
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      Ask FixBot
    4. Microsoft Surface Book 2 15" Heat Sink Replacement: step 4, image 1 of 1
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      Ask FixBot
    5. Microsoft Surface Book 2 15" Heat Sink Replacement: step 5, image 1 of 2 Microsoft Surface Book 2 15" Heat Sink Replacement: step 5, image 2 of 2
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      Ask FixBot
    6. Microsoft Surface Book 2 15" Heat Sink Replacement: step 6, image 1 of 2 Microsoft Surface Book 2 15" Heat Sink Replacement: step 6, image 2 of 2
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      Ask FixBot
    7. Microsoft Surface Book 2 15" Heat Sink Replacement: step 7, image 1 of 1
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      Ask FixBot
    1. Microsoft Surface Book 2 15" Heat Sink Replacement, Heat Sink: step 8, image 1 of 2 Microsoft Surface Book 2 15" Heat Sink Replacement, Heat Sink: step 8, image 2 of 2
      • With the motherboard removed flip it over.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Heat Sink Replacement: step 9, image 1 of 2 Microsoft Surface Book 2 15" Heat Sink Replacement: step 9, image 2 of 2
      • Remove the 4 torx 3 2.5mm screws holding in the heatsink.
      • Lift up and remove the heatsink. This requires a small amount of force.
      Ask FixBot
Ryan Picewick
537 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 82
All Time: 1,725
