Microsoft Surface Book 2 15" Battery Replacement
Views: 38K
View statistics:
Past 24 Hours:
25
Past 7 Days:
169
Past 30 Days:
737
All Time:
38,096
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 hours
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
WARNING: This guide is missing many steps.
This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard to be removed, which is very difficult to do without breaking the laptop.
The battery can also be very difficult to remove. The battery is secured to the laptop with very strong adhesive. It is recommended that you use isopropyl alcohol to soften the glue, making removal of the battery easier.
A majority of the issues that are found with this device can be solved through software solutions. Make sure to review the troubleshooting page and try the solutions listed there before making any repairs to the device.
Parts
Tools
    1. Microsoft Surface Book 2 15" Battery Replacement, Motherboard: step 1, image 1 of 1
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      Ask FixBot
    2. Microsoft Surface Book 2 15" Battery Replacement: step 2, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 2, image 2 of 2
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      Ask FixBot
    3. Microsoft Surface Book 2 15" Battery Replacement: step 3, image 1 of 1
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      Ask FixBot
    4. Microsoft Surface Book 2 15" Battery Replacement: step 4, image 1 of 1
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      Ask FixBot
    5. Microsoft Surface Book 2 15" Battery Replacement: step 5, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 5, image 2 of 2
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      Ask FixBot
    6. Microsoft Surface Book 2 15" Battery Replacement: step 6, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 6, image 2 of 2
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      Ask FixBot
    7. Microsoft Surface Book 2 15" Battery Replacement: step 7, image 1 of 1
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      Ask FixBot
    1. Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: step 8, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: step 8, image 2 of 2
      • Use an iOpener or a heat gun (on low heat) to carefully heat the back side of the tablet to help soften the battery adhesive.
      • Use prying tools such as a guitar pick, plastic card, or a nylon spudger to help sever the adhesive and gently lift the battery free.
      • After the case cools, a careful amount of isopropyl alcohol can help dissolve stubborn glue between the battery and the case.
      • Work slowly and carefully. Do not pry, bend, or puncture the battery while removing it from the tablet.
      Ask FixBot
5 other people completed this guide.
Ryan Picewick
537 Reputation
4 Guides authored
5 Guide Comments
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
Nicholas Law - Reply Share
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
darth mango - Reply Share
I also find it rather confusing.
Thanks darth mango.
Is it true that the battery in the Surface Book 2 has frequently failed completely?
No charging possible, always 0%.
When a battery ages, you can still charge it to 100%.
Very fast (bad), but “full”.
A total failure would rather be the battery management system.
I wonder if there were also failures of the charging current to the battery, i.e. a defect on the circuit board of the tablet screen.
That would be annoying, of course, because you can't just fix the fault by replacing the battery.
But replacing the entire battery would also be annoying if only the BMS is defective.
All you need is a replacement with comparable values and size, which you solder into the center of the battery.
And what about the assembly?
Are there adhesive strips in this form?
Or should you just use BT-7000 liquid glue?
I bought this for a Samsung Galaxy Note-9 to seal it watertight again after replacing the USB port.
Tobias Claren - Reply Share
Meine Akkus sind plötzlich auf 0% hängen geblieben. Aufladen nicht mehr möglich. Nur noch Netzbetrieb meines Surface 2. Schade. Akkutausch zu teuer.
Stefan Schwarz - Reply Share
Past 24 Hours: 25
Past 7 Days: 169
Past 30 Days: 737
All Time: 38,096
