Microsoft Surface 3 Speaker Replacement
    1. Microsoft Surface 3 Speaker Replacement, Casing: step 1, image 1 of 2 Microsoft Surface 3 Speaker Replacement, Casing: step 1, image 2 of 2
      • Warm up an iOpener following the instructions found in the iOpener guide.
      • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
      Ask FixBot
    2. Microsoft Surface 3 Speaker Replacement: step 2, image 1 of 2 Microsoft Surface 3 Speaker Replacement: step 2, image 2 of 2
      • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
      • This may take significant force. A fingernail might work better for the initial lift
      • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
      Ask FixBot
    3. Microsoft Surface 3 Speaker Replacement: step 3, image 1 of 2 Microsoft Surface 3 Speaker Replacement: step 3, image 2 of 2
      • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
      • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
      • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
      Ask FixBot
    4. Microsoft Surface 3 Speaker Replacement: step 4, image 1 of 1
      • Flip the display over so that parts underneath it are easily accessible.
      • Do not pull out the display as it is still attached to the motherboard.
      • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
      Ask FixBot
    1. Microsoft Surface 3 Speaker Replacement, Speaker: step 5, image 1 of 1
      • You will be working in these areas of the Surface 3 in order to replace the speakers.
      Ask FixBot
    2. Microsoft Surface 3 Speaker Replacement: step 6, image 1 of 1
      • Use a pick to get under the speaker part and undo the adhesive that keeps it attached to the back casing.
      Ask FixBot
    3. Microsoft Surface 3 Speaker Replacement: step 7, image 1 of 1
      • Use the pick to gently lift on the red and black wire in order to dislodge the connection between the speaker wire and the motherboard.
      Ask FixBot
    4. Microsoft Surface 3 Speaker Replacement: step 8, image 1 of 2 Microsoft Surface 3 Speaker Replacement: step 8, image 2 of 2
      • Repeat the same steps for the second speaker.
      Ask FixBot
    5. Microsoft Surface 3 Speaker Replacement: step 9, image 1 of 1
      • Simply replace the old speakers by snapping the new speakers into place and connecting the red and black wire to the motherboard.
      Ask FixBot
Andy Stone
284 Reputation
2 Guides authored
Cal Poly, Team 5-12, Maness Fall 2015 Member of Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 45
All Time: 4,121
