Microsoft Surface 3 Kickstand Replacement
Views: 10K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
93
All Time:
10,284
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replacing the kickstand is one of the simplest things to fix in a Surface 3. However, you will still need to take off the display and remove the battery to fully access the parts to replace.
Tools
    1. Microsoft Surface 3 Kickstand Replacement, Casing: step 1, image 1 of 2 Microsoft Surface 3 Kickstand Replacement, Casing: step 1, image 2 of 2
      • Warm up an iOpener following the instructions found in the iOpener guide.
      • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
      Ask FixBot
    2. Microsoft Surface 3 Kickstand Replacement: step 2, image 1 of 2 Microsoft Surface 3 Kickstand Replacement: step 2, image 2 of 2
      • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
      • This may take significant force. A fingernail might work better for the initial lift
      • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
      Ask FixBot
    3. Microsoft Surface 3 Kickstand Replacement: step 3, image 1 of 2 Microsoft Surface 3 Kickstand Replacement: step 3, image 2 of 2
      • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
      • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
      • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
      Ask FixBot
    4. Microsoft Surface 3 Kickstand Replacement: step 4, image 1 of 1
      • Flip the display over so that parts underneath it are easily accessible.
      • Do not pull out the display as it is still attached to the motherboard.
      • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
      Ask FixBot
    1. Microsoft Surface 3 Kickstand Replacement, Battery: step 5, image 1 of 1
      • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
      Ask FixBot
    2. Microsoft Surface 3 Kickstand Replacement: step 6, image 1 of 3 Microsoft Surface 3 Kickstand Replacement: step 6, image 2 of 3 Microsoft Surface 3 Kickstand Replacement: step 6, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Slide the iFixit plastic cards under the compartments of the battery pack.
      • Slide the card around to undo the adhesive under the battery pack
      Ask FixBot
    3. Microsoft Surface 3 Kickstand Replacement: step 7, image 1 of 3 Microsoft Surface 3 Kickstand Replacement: step 7, image 2 of 3 Microsoft Surface 3 Kickstand Replacement: step 7, image 3 of 3
      • Carefully slide the battery's flat power and data connector from its insert.
      • You may now switch out the battery pack for a new one.
      Ask FixBot
    1. Microsoft Surface 3 Kickstand Replacement, Kickstand: step 8, image 1 of 2 Microsoft Surface 3 Kickstand Replacement, Kickstand: step 8, image 2 of 2
      • Remove these four 3/32" Torx #3 screws.
      • If you do not need to remove the hinges, skip to the step that handles the retaining tabs.
      Ask FixBot
    2. Microsoft Surface 3 Kickstand Replacement: step 9, image 1 of 2 Microsoft Surface 3 Kickstand Replacement: step 9, image 2 of 2
      • Remove these four 3/16" Torx #5 screws that hold in the hinges to replace the hinges.
      Ask FixBot
    3. Microsoft Surface 3 Kickstand Replacement: step 10, image 1 of 3 Microsoft Surface 3 Kickstand Replacement: step 10, image 2 of 3 Microsoft Surface 3 Kickstand Replacement: step 10, image 3 of 3
      • These two retaining tabs need to be fed through the slots in the case to release the kickstand.
      • Use picks to make the tab slide through the slot then simply pull out the kickstand,
      Ask FixBot
4 other people completed this guide.
Harold Hall
1,332 Reputation
3 Guides authored
Cal Poly, Team 5-12, Maness Fall 2015 Member of Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Members
72 Guides authored
2 Guide Comments
I think I will NOT be trying to do this. To many potentials for something to go wrong beyond your control, even when being extra careful. I do not feel like replacing someone’s device if that happens.
QuickTech - Reply Share
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
Tilly Mortimore - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 93
All Time: 10,284
