Up to 20% off select tools
Microsoft Surface 2 Volume Control Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
93
All Time:
2,346
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your volume control button has been getting stuck or malfunctioning, it is very likely that it needs to be replaced. This guide is a step by step process on how to go about fixing it.
    1. Microsoft Surface 2 Volume Control Replacement, Screen: step 1, image 1 of 3 Microsoft Surface 2 Volume Control Replacement, Screen: step 1, image 2 of 3 Microsoft Surface 2 Volume Control Replacement, Screen: step 1, image 3 of 3
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Ask FixBot
    2. Microsoft Surface 2 Volume Control Replacement: step 2, image 1 of 3 Microsoft Surface 2 Volume Control Replacement: step 2, image 2 of 3 Microsoft Surface 2 Volume Control Replacement: step 2, image 3 of 3
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Ask FixBot
    1. Microsoft Surface 2 Volume Control Replacement, Volume Control: step 3, image 1 of 2 Microsoft Surface 2 Volume Control Replacement, Volume Control: step 3, image 2 of 2
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Ask FixBot
    2. Microsoft Surface 2 Volume Control Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Gently peel off the yellow plastic tape using a pair of tweezers.
      Ask FixBot
    3. Microsoft Surface 2 Volume Control Replacement: step 5, image 1 of 1
      • Remove the two 1.70 mm T3 screws from the volume control switch.
      Ask FixBot
    4. Microsoft Surface 2 Volume Control Replacement: step 6, image 1 of 1
      • Use a spudger to lift up the retaining flap on the volume control cable ZIF connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      Ask FixBot
    5. Microsoft Surface 2 Volume Control Replacement: step 7, image 1 of 1
      • Now that the volume control switch is loose, pull it gently away from the motherboard.
      • No force is needed to plug in or remove the ribbon cable.
      Ask FixBot
Author
with
oluchianya
157 Reputation
1 Guide authored
USF Tampa, Team 3-1, Wollert Spring 2016 Member of USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 93
All Time: 2,346
