Microsoft Surface 2 Speaker Replacement
    1. Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 1 of 3 Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 2 of 3 Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 3 of 3
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Ask FixBot
    2. Microsoft Surface 2 Speaker Replacement: step 2, image 1 of 3 Microsoft Surface 2 Speaker Replacement: step 2, image 2 of 3 Microsoft Surface 2 Speaker Replacement: step 2, image 3 of 3
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Ask FixBot
    1. Microsoft Surface 2 Speaker Replacement, Speaker: step 3, image 1 of 2 Microsoft Surface 2 Speaker Replacement, Speaker: step 3, image 2 of 2
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Ask FixBot
    2. Microsoft Surface 2 Speaker Replacement: step 4, image 1 of 1
      • Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
      Ask FixBot
    3. Microsoft Surface 2 Speaker Replacement: step 5, image 1 of 2 Microsoft Surface 2 Speaker Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the cable connecting the speaker to the motherboard.
      • Peel up the tiny strip of yellow tape securing the cable to the motherboard.
      Ask FixBot
    4. Microsoft Surface 2 Speaker Replacement: step 6, image 1 of 2 Microsoft Surface 2 Speaker Replacement: step 6, image 2 of 2
      • Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
      Ask FixBot
EG1
612 Reputation
2 Guides authored
USF Tampa, Team 3-1, Wollert Spring 2016 Member of USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 34
All Time: 1,867
