Up to 20% off select tools
Microsoft Surface 2 I/O Cable Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
106
All Time:
5,659
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you have tried multiple times but cannot get the Microsoft Surface 2 to turn on, you may need to replace the I/O cable, which houses the charging port. This cable will also need to be replaced if your SD card slot is not working properly.
    1. Microsoft Surface 2  I/O Cable Replacement, Screen: step 1, image 1 of 3 Microsoft Surface 2  I/O Cable Replacement, Screen: step 1, image 2 of 3 Microsoft Surface 2  I/O Cable Replacement, Screen: step 1, image 3 of 3
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Ask FixBot
    2. Microsoft Surface 2  I/O Cable Replacement: step 2, image 1 of 3 Microsoft Surface 2  I/O Cable Replacement: step 2, image 2 of 3 Microsoft Surface 2  I/O Cable Replacement: step 2, image 3 of 3
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Ask FixBot
    1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: step 3, image 1 of 2 Microsoft Surface 2  I/O Cable Replacement, I/O Cable: step 3, image 2 of 2
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Ask FixBot
    2. Microsoft Surface 2  I/O Cable Replacement: step 4, image 1 of 2 Microsoft Surface 2  I/O Cable Replacement: step 4, image 2 of 2
      • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
      • Remove the two 3.27 mm T3 screws holding down the charging port.
      Ask FixBot
    3. Microsoft Surface 2  I/O Cable Replacement: step 5, image 1 of 3 Microsoft Surface 2  I/O Cable Replacement: step 5, image 2 of 3 Microsoft Surface 2  I/O Cable Replacement: step 5, image 3 of 3
      • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
      • The retaining chip may be glued to the motherboard.
      • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      • Remove the ribbon cable from its port.
      • No force is needed to plug in or remove the ribbon cable.
      Ask FixBot
4 other people completed this guide.
Author
with
Gregory Miller
415 Reputation
1 Guide authored
USF Tampa, Team 3-1, Wollert Spring 2016 Member of USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Members
60 Guides authored
2 Guide Comments
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - Reply Share
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 106
All Time: 5,659
