Microsoft Lumia 950 XL Screen Replacement
    1. Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 3 of 3
      • The Lumia 950 XL back cover is super easy to remove. There is a dent at the bottom of the phone to guide you to where you should start working.
      • Crack the back cover open using your fingers.
      • Lift the battery out using your fingers.
      • Everything should pop out easily since there is no glue or adhesive to worry about.
      • Make sure to remove the SIM card or microSD card if they are inserted.
      Ask FixBot
    2. Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 3 of 3
      • Unscrew the 12 Torx screws (T5) in the back panel.
      • Lift the back plate from the bottom of the phone.
      • To remove this back panel, there is a clasp hidden beneath the round camera cut out. Use a tweezer to gently remove it. No force is required.
      Ask FixBot
    3. Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 3 of 3
      • Now that the back plate is off, it shows various interesting components like the heat pipe, earpiece & loud speaker.
      • Remove the headphone jack connector using a spudger. Then lift using a tweezer.
      Ask FixBot
    4. Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 3 of 3
      • There are three connectors that need to be disconnected before working with the motherboard.
      • With a spudger, remove the first two connectors.
      • Another small connector is connected with the side buttons. Again, disconnect them using a spudger.
      Ask FixBot
    5. Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • The motherboard is clipped with the back of the display panel.
      • Start working with the top right of the phone. Remove the motherboard from the clip by hand or use a Jimmy to leverage in little force to make it easier.
      • Use tweezers to lift the motherboard up. This may require a little force since this part of the board has little clips underneath.
      • Continue working with the motherboard all the way around till the bottom half of the phone. Straightforward!
      Ask FixBot
    6. Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 3 of 3
      • One last connector needs to be disconnected on the back of the motherboard.
      • Start by peeling of the sticker beneath the battery.
      • Lift the motherboard up, starting from the bottom of the phone, and flip it gently. You will see the hidden connector.
      • This connector also connect the motherboard to the daughter board.
      • Disconnect it with a spudger
      • Now the motherboard can be removed.
      Ask FixBot
    7. Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 3 of 3
      • Remove the two connectors that connect the daughter board with the motherboard. They are lightly adhered in place and can be peeled off easily by hand.
      • Remove the daughter board by using a spudger.
      Ask FixBot
    8. Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 3 of 3
      • Remove the vibrating motor using a spudger.
      • Remove the side panel with a spudger. It is lightly adhered but can be lifted by fingers or a tweezer.
      Ask FixBot
    9. Microsoft Lumia 950 XL Screen Replacement, Insert components into new screen: step 9, image 1 of 2 Microsoft Lumia 950 XL Screen Replacement, Insert components into new screen: step 9, image 2 of 2
      • Start the assembly process by placing the daughter board into the new screen
      • Place the vibrating motor back into its place.
      • The new screen should come with a light adhesive to hold the two cables from the daughterboard.
      Ask FixBot
    10. Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 3 of 3
      • Reconnect a connector on the back of the motherboard, clipping the board in place. Start with the top right corner of the phone and push the motherboard into the clips using a spudger.
      • Reconnect all 3 connectors.
      Ask FixBot
    11. Microsoft Lumia 950 XL Screen Replacement, The return of the headphone Jack!!: step 11, image 1 of 1
      • Place the headphone jack and connect it to the motherboard.
      • Reapply the sticker beneath the battery
      • Well, this can be done later after trying to turn on the device.
      • Place the back panel on top of the motherboard, and screw in all 12 screws!
      Ask FixBot
    12. Microsoft Lumia 950 XL Screen Replacement, And we are done!!: step 12, image 1 of 1
      • After closing of the back cover, try turning the phone on!!
      • This replacement part is an OLED screen. It is much higher quality compared with the LCD replacement screen.
      Ask FixBot
Thank you for following us. This is a complete disassembly - replacement - reassembly guide. So, your phone should be working normally again!
7 other people completed this guide.
Anan Venasakulchai
1,059 Reputation
2 Guides authored
Finn Store Member of Finn Store
Business
1 Member
24 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 92
All Time: 5,015
