Microsoft Lumia 532 Dual SIM Disassembly
    1. Microsoft Lumia 532 Dual SIM Disassembly, Removing the obstacles: step 1, image 1 of 3 Microsoft Lumia 532 Dual SIM Disassembly, Removing the obstacles: step 1, image 2 of 3 Microsoft Lumia 532 Dual SIM Disassembly, Removing the obstacles: step 1, image 3 of 3
      • Remove your SD card, battery, SIM(s) and cover. To remove the cover, you grab the top of it and put your thumb on the middle of the case and pull towards yourself.
      • Hmmm... I wonder what that part (marked in green) does....
      Ask FixBot
      • Unfortunately, because I don't have the necessary tools to continue this teardown, I will let anyone with a Lumia 532 (Dual SIM or not) continue this guide and improve it.
      • Tip: If you don't have a Torx Screw Driver or bit, use a small flat screw driver. Align it in a position where you can spin the Torx screws safely. This chips the paint off the screws, though.
      Ask FixBot
Finish Line
2 other people completed this guide.
[deleted]
283 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 37
All Time: 2,239
