Up to 20% off select tools
Microsoft LXM-00001 Keycap Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
82
All Time:
386
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If a key on your Microsoft LXM-00001 device feels loose, sticks, fails to spring back, or won’t register presses, use this guide to replace the affected keycap. Keycaps can crack or lose their hinge mechanism, which leads to inconsistent or difficult typing. Power off and disconnect the device to avoid accidental input during the repair, and use the correct tools to prevent damage.
    1. Microsoft LXM-00001 Keycap Replacement, Keycap: step 1, image 1 of 3 Microsoft LXM-00001 Keycap Replacement, Keycap: step 1, image 2 of 3 Microsoft LXM-00001 Keycap Replacement, Keycap: step 1, image 3 of 3
      • Position a nylon spudger under one side of the keycap.
      • If the key is hard to get under, use a keycap puller.
      • Lift straight up by using a steady and even force to remove the keycap.
      • Avoid twisting or angling the cap while pulling to protect the scissor mechanism.
      Ask FixBot
Author
with
Mary Green
409 Reputation
4 Guides authored
Texas Tech, Team 2-1, Johansen Fall 2025 Member of Texas Tech, Team 2-1, Johansen Fall 2025
TTU-JOHANSEN-F25S2G1
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 82
All Time: 386
