Up to 20% off select tools
Microsoft Bluetooth Ergonomic Mouse Shell Disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
45
Past 30 Days:
206
All Time:
738
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Microsoft Bluetooth Ergonomic Mouse (model 1955) need any internal modifications or repairs to internal components (excluding batteries), This guide will help you to remove the outer and inner shells for internal access.
If any button, scroll, click, sensor, power, bluetooth hardware, or circuit board and wires are compromised, removal of the ergonomic shells are necessary to repair or replace those components.
When removing the shell with the pry tool be cautious not to damage the plastic of the shell when prying. Try to use plastic pry tools to limit damage on other plastic. Be more cautious if using a metal pry tool.
Before beginning, make sure to power off your mouse completely and disconnect from any external power source.
    1. Microsoft Bluetooth Ergonomic Mouse Shell Disassembly, Shell: step 1, image 1 of 2 Microsoft Bluetooth Ergonomic Mouse Shell Disassembly, Shell: step 1, image 2 of 2
      • Remove the battery cover and take out both AAA batteries from the mouse.
      • At this point, the mouse should have no power source and be safe to work on.
      Ask FixBot
    2. Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 2, image 1 of 2 Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 2, image 2 of 2
      • Insert a thin pry tool beneath the seam near the left and right click buttons.
      • Slide the pry tool toward the rear of the mouse while keeping the tool underneath the upper shell clips.
      • Gently release the retaining clips securing the top shell.
      • Continue working around the shell until the top cover separates from the lower housing.
      Ask FixBot
    3. Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 3, image 1 of 2 Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 3, image 2 of 2
      • Remove the three 7.1 mm T6 Torx screws securing the inner shell.
      Ask FixBot
    4. Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 4, image 1 of 2 Microsoft Bluetooth Ergonomic Mouse Shell Disassembly: step 4, image 2 of 2
      • Open the inner shell carefully from left to right to access the internal circuits.
      • Do not pull on the wires connecting the upper and lower shell components.
      Ask FixBot
Author
with
Giovanny Tammick-Concepcion
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 45
Past 30 Days: 206
All Time: 738
