Introduction
This guide explains how to replace the optical sensor lens in a Microsoft Bluetooth Ergonomic Mouse if the sensor is damaged or no longer functioning properly.
The optical sensor detects surface movement and translates that motion into cursor movement on your computer. A faulty sensor may cause the cursor to move inconsistently, inaccurately, or not at all.
Before proceeding, inspect the sensor opening for dust, debris, or surface damage that may be interfering with tracking. Test the mouse on multiple surfaces and verify your motion settings to confirm the optical sensor is the source of the issue.
Before beginning, power off the mouse and disconnect it from any external power source.
Insert a thin pry tool beneath the seam near the left and right click buttons.
Slide the pry tool toward the rear of the mouse while keeping the tool underneath the upper shell clips.
Gently release the retaining clips securing the top shell.
Continue working around the shell until the top cover separates from the lower housing.
Use tweezers to lift and disconnect the two JST connectors secured to the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
