Microsoft Band Wrist Clasp Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
83
All Time:
5,680
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
You might try keeping track of the screws with the use of a magnetic mat.
Tools
    1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: step 1, image 1 of 1
      • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
      Ask FixBot
    2. Microsoft Band Wrist Clasp Replacement: step 2, image 1 of 1
      • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
      Ask FixBot
    3. Microsoft Band Wrist Clasp Replacement: step 3, image 1 of 1
      • Pull the two securing pins out of the rubberized part of the band.
      Ask FixBot
Chad Steese
259 Reputation
2 Guides authored
Cal Poly, Team 17-34, Amido Winter 2015 Member of Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Members
72 Guides authored
3 Guide Comments
where can I purchase the replacement part
jeepgirlutah - Reply Share
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - Reply Share
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 83
All Time: 5,680
