Microsoft Band Sensor Ribbon Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
85
All Time:
2,712
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The sensor ribbon connects the microphone, UV sensor, and buttons to the device
Warning: The following guide is likely to ruin the water resistance of the device.
Parts
  • Spudger
    4.9
    1. Microsoft Band Sensor Ribbon Replacement, Screen Frame: step 1, image 1 of 1
      • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
      • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
      • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
      • When using the iOpener, make sure to wrap it partially around the sides.
      Ask FixBot
    2. Microsoft Band Sensor Ribbon Replacement: step 2, image 1 of 1
      • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
      • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
      Ask FixBot
    3. Microsoft Band Sensor Ribbon Replacement: step 3, image 1 of 2 Microsoft Band Sensor Ribbon Replacement: step 3, image 2 of 2
      • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
      • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
      • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
      • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
      Ask FixBot
    1. Microsoft Band Sensor Ribbon Replacement, LCD Screen: step 4, image 1 of 1
      • Do not rip the yellow ribbon cable from the motherboard.
      • Gently lift the LCD screen from the components using your fingertips.
      Ask FixBot
    2. Microsoft Band Sensor Ribbon Replacement: step 5, image 1 of 1
      • Lightly pry up the black connector from the motherboard using a spudger.
      • Pull the entire LCD screen gently upward to detach the yellow ribbon cable.
      Ask FixBot
    1. Microsoft Band Sensor Ribbon Replacement, Sensor Ribbon: step 6, image 1 of 2 Microsoft Band Sensor Ribbon Replacement, Sensor Ribbon: step 6, image 2 of 2
      • Handle the ribbon with care to prevent damage. Do not bend the ribbon unless specified.
      • Using the spudger or the plastic opening tool, gently unhook the golden ribbon from the corner on the opposite side of the buttons. The part of the ribbon with the three boxes should then easily be detached from the band.
      Ask FixBot
    2. Microsoft Band Sensor Ribbon Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Using your fingers or tweezers, gently pull the band from away from the motherboard to detach the strip from the buttons.
      Ask FixBot
Chad Steese
259 Reputation
2 Guides authored
Cal Poly, Team 17-34, Amido Winter 2015 Member of Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Members
72 Guides authored
2 Guide Comments
Excellent guide. I had trouble with my screen and although it could not be fixed, this is the best guide online for this product.
clewis97 - Reply Share
Where can I find a sensor ribbon to buy?
maptan - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 85
All Time: 2,712
