Up to 20% off select tools
Microsoft Band Screen Frame Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
92
All Time:
1,671
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
  • iOpener
    $24.95
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The frame is attached to the body of the Band with adhesive on the back side. This guide uses an iFixit iOpener to soften this adhesive so the frame can be removed.
Warning: The following guide is likely to ruin the water resistance of the device.
    1. Microsoft Band Screen Frame Replacement, Screen Frame: step 1, image 1 of 1
      • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
      • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
      • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
      • When using the iOpener, make sure to wrap it partially around the sides.
      Ask FixBot
    2. Microsoft Band Screen Frame Replacement: step 2, image 1 of 1
      • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
      • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
      Ask FixBot
    3. Microsoft Band Screen Frame Replacement: step 3, image 1 of 2 Microsoft Band Screen Frame Replacement: step 3, image 2 of 2
      • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
      • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
      • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
      • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
      Ask FixBot
Author
with
Alan Robison
194 Reputation
1 Guide authored
Cal Poly, Team 17-34, Amido Winter 2015 Member of Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Members
72 Guides authored
2 Guide Comments
Where do you purchase the new screen frame? I can't seem to locate where to purchase the replacement parts.
TImmyk - Reply Share
Where can I get band 2 screen cover or just parts?
Alex - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 92
All Time: 1,671
