Up to 20% off select tools
Microsoft Band Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
103
All Time:
12,955
Comments: 5
5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Parts
Tools
  • Spudger
    4.9
  • T3 Torx Screwdriver
    4.8
Introduction
Go to step 1 ↓
There are two batteries in the band, located in the side panels. One battery compartment contains a vibrator, but the replacement steps are essentially the same.
Warning: The following guide is likely to ruin the water resistance of the device.
    1. Microsoft Band Battery Replacement, Battery: step 1, image 1 of 1
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      Ask FixBot
    2. Microsoft Band Battery Replacement: step 2, image 1 of 1
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      Ask FixBot
    3. Microsoft Band Battery Replacement: step 3, image 1 of 1
      • Gently pry up one edge of the battery with the plastic spudger.
      Ask FixBot
    4. Microsoft Band Battery Replacement: step 4, image 1 of 1
      • Remove battery from its compartment with your fingers.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
5 other people completed this guide.
Author
with
Monique Salinger
408 Reputation
2 Guides authored
Cal Poly, Team 17-34, Amido Winter 2015 Member of Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Members
72 Guides authored
5 Guide Comments
where can i buy the battery?
chirac - Reply Share
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Reply Share
Will this be dangerous?
Rei zzstu Shiozawa - Reply Share
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Reply Share
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 103
All Time: 12,955
