Up to 20% off select tools
Microsoft Band 2 Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
102
All Time:
2,611
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will cover how to remove the screen of the Microsoft Band 2 smartwatch. If the display is blank or dim it may be advantageous to consider replacing the screen on the Band 2.
    1. Microsoft Band 2 Screen Replacement, Screen: step 1, image 1 of 1
      • Wear proper gloves when using a heatgun.
      • Use a heatgun to melt the adhesive beneath the screen. Heat the metal around edges of the screen.
      • Avoid heating the rubber watch band as it will quickly melt.
      • Heating the LCD screen may damage it. Avoid this procedure unless you intend to replace the screen.
      Ask FixBot
    2. Microsoft Band 2 Screen Replacement: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $2.99
      Buy
      Ask FixBot
    3. Microsoft Band 2 Screen Replacement: step 3, image 1 of 2 Microsoft Band 2 Screen Replacement: step 3, image 2 of 2
      Buy
      • Use metal tweezers to gently detach the orange press-fit (or "pop") connector.
      Ask FixBot
6 other people completed this guide.
Author
with
Chris Syracuse
639 Reputation
3 Guides authored
USF Tampa, Team S1-G5, Leahy Spring 2017 Member of USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 Members
48 Guides authored
2 Guide Comments
where I can buy microsoft band 2 screen. thanks
fredsonyo - Reply Share
Way too Late lol.
Rowdy Bedsaul - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 102
All Time: 2,611
