Miadore Classic N64 Controller Joystick Replacement
  1. Miadore Classic N64 Controller Joystick Replacement, Joystick: step 1, image 1 of 3 Miadore Classic N64 Controller Joystick Replacement, Joystick: step 1, image 2 of 3 Miadore Classic N64 Controller Joystick Replacement, Joystick: step 1, image 3 of 3
    • Use a Phillips #000 screwdriver to remove all nine 3.2 mm screws from the back of the controller.
    • Place the end of a spudger in the seam between the top and bottom of the controller to release the clips holding them together.
    • Separate the top and bottom cover of the controller.
    Ask FixBot
  2. Miadore Classic N64 Controller Joystick Replacement: step 2, image 1 of 2 Miadore Classic N64 Controller Joystick Replacement: step 2, image 2 of 2
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
    Ask FixBot
  3. Miadore Classic N64 Controller Joystick Replacement: step 3, image 1 of 3 Miadore Classic N64 Controller Joystick Replacement: step 3, image 2 of 3 Miadore Classic N64 Controller Joystick Replacement: step 3, image 3 of 3
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
    Ask FixBot
  4. Miadore Classic N64 Controller Joystick Replacement: step 4, image 1 of 2 Miadore Classic N64 Controller Joystick Replacement: step 4, image 2 of 2
    • Remove the joystick by pulling it away from the plastic needle-like object holding it in place.
    • Replace it with a new or custom joystick.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. If all goes well, the joystick should work good as new.
2 other people completed this guide.
Anderson Rodriguez
213 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 52
All Time: 843
