Miadore Classic N64 Controller Buttons Replacement
    1. Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 3 of 3
      • Use a Phillips #000 screwdriver to remove all nine 3.2 mm screws from the back of the controller.
      • Place the end of a spudger in the seam between the top and bottom of the controller to release the clips holding them together.
      • Separate the top and bottom cover of the controller.
      Ask FixBot
    2. Miadore Classic N64 Controller Buttons Replacement: step 2, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 2, image 2 of 2
      • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
      • The motherboard will still be in place after the screws are removed.
      Ask FixBot
    3. Miadore Classic N64 Controller Buttons Replacement: step 3, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 3, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 3, image 3 of 3
      • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
      • Remove the joystick module.
      Ask FixBot
    4. Miadore Classic N64 Controller Buttons Replacement: step 4, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 4, image 2 of 2
      • Remove the joystick by pulling it away from the plastic needle-like object holding it in place.
      • Replace it with a new or custom joystick.
      Ask FixBot
    1. Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 3 of 3
      • Remove the right and left bumper.
      • If the bumper buttons are the buttons that need to be replaced, you can stop here.
      Ask FixBot
    2. Miadore Classic N64 Controller Buttons Replacement: step 6, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 6, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 6, image 3 of 3
      • Pull the motherboard up with even pressure on all sides.
      • Set the motherboard to the side.
      Ask FixBot
    3. Miadore Classic N64 Controller Buttons Replacement: step 7, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 7, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 7, image 3 of 3
      • Remove the rubber gaskets.
      • This will reveal the buttons underneath.
      Ask FixBot
    4. Miadore Classic N64 Controller Buttons Replacement: step 8, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 8, image 2 of 2
      • Push up from the bottom of the controller to pop the buttons out.
      Ask FixBot
3 other people completed this guide.
angel villagomez
313 Reputation
1 Guide authored
CSU Los Angeles, Team 5-3, Kershman Fall 2024 Member of CSU Los Angeles, Team 5-3, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G3
5 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 25
All Time: 421
