MiJia Bluetooth Thermometer (2 Battery) Replacement
    1. MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: step 1, image 1 of 3 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: step 1, image 2 of 3 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: step 1, image 3 of 3
      • Insert the flat side of your spudger or your finger nail into the crack located the back-bottom of the device.
      • While inserted, use gentle force to lift the bottom up, then, use a Opening pick or your finger to remove all the clips.
      • The bottom should detach.
      Ask FixBot
    2. MiJia Bluetooth Thermometer (2 Battery) Replacement, Change Battery: step 2, image 1 of 1
      • You need a spare CR2032 battery.
      • Remove the old battery and attach new battery from top.
      Ask FixBot
You might need to wait few minute before the temperature synced up.
2 other people completed this guide.
wiiiw
133 Reputation
1 Guide authored
1 Guide Comment
Thanks bro, that was really helpful and presented in a simple and easy way!
Kira Great - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 601
