Introduction
Use this guide to replace the rear glass on your Xiaomi Mi 11.
You’ll need replacement adhesive to reattach components when reassembling the device.
Note: In this guide we’re using a teardown device. This means that the motherboard has been deshielded during the teardown procedure. You can still do all the repairs with this guide but your motherboard will look like this.
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your Xiaomi Mi 11 to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 other people completed this guide.
1 Guide Comment
, j'ai besoin d'une vitre arrière Xiaomi mi 11 bleu original
