Up to 20% off select tools
Metal Snap Installation Using a Hand Press
Views: 27K
View statistics:
Past 24 Hours:
16
Past 7 Days:
90
Past 30 Days:
453
All Time:
26,947
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
Metal snaps are essential for securely fastening heavy-duty fabrics on packs and jackets, such as those in the Patagonia Work Wear line. A metal snap can fail if it becomes crushed or is pulled off, requiring a new one to be installed.
This guide will demonstrate how to install a metal snap without the need for sewing. To ensure this solution is applicable, confirm that both sides of the damaged snap (the cap and the socket/stud) are visible. Additionally, check the fabric around the old snap for tears or damage beyond a small hole. If the fabric is compromised, a reinforcing patch will need to be sewn on before replacing the snap.
This guide is for professional repair technicians with access to a tabletop hand press.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Related tutorial: Plastic Snap Installation Using a Hand Press
Return to the Patagonia Care & Repair homepage.
    1. Metal Snap Installation Using a Hand Press, Metal snap types: step 1, image 1 of 2 Metal Snap Installation Using a Hand Press, Metal snap types: step 1, image 2 of 2
      • There are two main styles of metal snaps on Patagonia gear:
      • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
      • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
      • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
      Ask FixBot
    2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: step 2, image 1 of 2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: step 2, image 2 of 2
      • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
      • Gather the stud and post pieces and their corresponding dies.
      • The stud and post are compressed together with the press to create the base of the snap.
      Ask FixBot
    3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 3 of 3
      • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
      Ask FixBot
    4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: step 4, image 1 of 2 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: step 4, image 2 of 2
      • Insert the post die into the lower fitting of the hand press.
      Ask FixBot
    5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 3 of 3
      • Insert the stud piece into the stud die until it snaps into place.
      Ask FixBot
    6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 3 of 3
      • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
      • Insert the die upward and hold it in place.
      • Tighten the tightening mechanism.
      Ask FixBot
    7. Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 1 of 3 Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 2 of 3 Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 3 of 3
      • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
      • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
      • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
      • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
      • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
      Ask FixBot
    8. Metal Snap Installation Using a Hand Press, Quality control: step 8, image 1 of 2 Metal Snap Installation Using a Hand Press, Quality control: step 8, image 2 of 2
      • Release the handle of the hand press and remove the fabric.
      • Inspect both sides of the snap to make sure:
      • It is not cracked, crushed, or misshapen.
      • It's laying flat and flush up against the fabric.
      • It doesn't spin in place.
      • It fastens together securely with the head of the snap.
      • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
      Ask FixBot
    9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: step 9, image 1 of 2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: step 9, image 2 of 2
      • Gather the socket and cap pieces and their corresponding dies.
      • The socket and cap are compressed together with the press to create the head of the snap.
      Ask FixBot
    10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 3 of 3
      • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
      Ask FixBot
    11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 3 of 3
      • Insert the cap die into the lower fitting of the hand press.
      Ask FixBot
    12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: step 12, image 1 of 2 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: step 12, image 2 of 2
      • Insert the socket piece into the socket die until it snaps into place.
      Ask FixBot
    13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 3 of 3
      Ask FixBot
    14. Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 1 of 3 Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 2 of 3 Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 3 of 3
      Ask FixBot
    15. Metal Snap Installation Using a Hand Press, Quality control: step 15, image 1 of 2 Metal Snap Installation Using a Hand Press, Quality control: step 15, image 2 of 2
      • It fastens together securely with the base of the snap.
      Ask FixBot
    16. Metal Snap Installation Using a Hand Press, Examples: step 16, image 1 of 2 Metal Snap Installation Using a Hand Press, Examples: step 16, image 2 of 2
      • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
      • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 90
Past 30 Days: 453
All Time: 26,947
