Up to 20% off select tools
Meta Quest 3 Controller Strap Replacement
Views: 11K
View statistics:
Past 24 Hours:
29
Past 7 Days:
156
Past 30 Days:
543
All Time:
10,732
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Have you ever wanted to add accessory's to your oculus quest but were afraid to break something, or simply not know how? In this guide I will go over how to apply the Meta Quest Active Straps for the oculus quest 3 controllers. I will guide you step-by-step to ensure you do not break anything and know how to properly apply the accessory.
    1. Meta Quest 3 Controller Strap Replacement, Controller straps: step 1, image 1 of 1
      • First, you will want to pick up any of the controllers to begin replacing the wrist strap.
      Ask FixBot
    2. Meta Quest 3 Controller Strap Replacement: step 2, image 1 of 1
      • Adjacent to the controller's joystick is a white triangle button.
      • You need to press down firmly on the button to open the controller's battery compartment.
      Ask FixBot
    3. Meta Quest 3 Controller Strap Replacement: step 3, image 1 of 2 Meta Quest 3 Controller Strap Replacement: step 3, image 2 of 2
      • Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
      Ask FixBot
    4. Meta Quest 3 Controller Strap Replacement: step 4, image 1 of 1
      • Grab the corresponding wrist strap for the controller you are working on.
      Ask FixBot
    5. Meta Quest 3 Controller Strap Replacement: step 5, image 1 of 2 Meta Quest 3 Controller Strap Replacement: step 5, image 2 of 2
      • With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
      Ask FixBot
    6. Meta Quest 3 Controller Strap Replacement: step 6, image 1 of 2 Meta Quest 3 Controller Strap Replacement: step 6, image 2 of 2
      • You can close the battery compartment using the new cover connected to the controller strap.
      • Closing the battery compartment can be frustrating because it is connected to the strap; I found it easier to slide the cover from the bottom to the top.
      • The new controller straps come with new battery compartment covers, so when you replace the straps, you will end up with spare parts.
      Ask FixBot
    7. Meta Quest 3 Controller Strap Replacement: step 7, image 1 of 3 Meta Quest 3 Controller Strap Replacement: step 7, image 2 of 3 Meta Quest 3 Controller Strap Replacement: step 7, image 3 of 3
      • Put the controller in your hands to see if you need to adjust the fit of the strap.
      • If Adjustments are needed, you can pull or push the strap through the clip's hole.
      Ask FixBot
    8. Meta Quest 3 Controller Strap Replacement: step 8, image 1 of 2 Meta Quest 3 Controller Strap Replacement: step 8, image 2 of 2
      • Next, repeat steps 2-7 on the second controller.
      • As mentioned in step 6, you will have spare parts left over from the original wrist strap and battery cover. Store these parts somewhere safe if you ever feel like reverting to the original controller straps.
      Ask FixBot
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
2 other people completed this guide.
Author
with
Andrew28709
184 Reputation
1 Guide authored
1 Guide Comment
how do o fix my controller
Zzopekvr VR - Reply Share
Past 24 Hours: 29
Past 7 Days: 156
Past 30 Days: 543
All Time: 10,732
