Up to 20% off select tools
Meta Quest 2 test USB port
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
93
All Time:
1,015
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
      • Hi!
      • If your Meta Quest 2 does not connect via USB, or the connection only works via USB 2.0, the connector on the cable or chip on the motherboard may be damaged. Below, I will show you how to test (based on comparing two Meta Quests, one with issues in the USB part and the other with no issues).
      Ask FixBot
    1. Meta Quest 2 test USB port: step 2, image 1 of 1
      • You need a USB3.0 testing plat like this, and/or open the Oculus Quest 2 body like in this tutorial until step 6:
      • Oculus Quest 2 Disassembly
      Ask FixBot
      • If you insert the test board as shown in the photo, then: D- and D+ are the pins of the USB2.0 part of the connector; A2,A3 & A10,A11 & B2,B3 & B10,B11 are the TX and RX pairs of the USB3.0 part
      • The TX and RX pairs of USB 3.0 should be the same in both directions and A10-A11 & B10-B11 must be 600+\- during diode call in both directions
      Ask FixBot
    2. Meta Quest 2 test USB port: step 4, image 1 of 1
      • By disconnecting the connector from the board, you can see a picture as in the photo. The purple mark is the first pin of the connector. Let it be #1, and let it be #2 to the left, then:
      • #2 will be B11 & #3 will be B10
      • #5 will be A2 & #6 will be A3
      • #8 will be A10 & #9 will be A11
      • #11 will be B3 & #12 will be B2
      • In the second row, same counting from the right:
      • #4 will be D+ & #5 will be D-
      Ask FixBot
      • Four green strokes in the previous photo - these are the same A11-A10 and B11-B10 after the multiplexers (the most delicate and unprotected parts of the port - they damaged first)
      • There are no separation capacitors, as you can see (due to the required wire length).
      • If they get a supply voltage or a signal from the USB2.0 part - they burn out and stop diod calling mirrorily.
      • As far as I know, the damage is irreversible and occurs in the main chip on the board (repair is not advisable).
      Ask FixBot
Author
with
Dmitry
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 93
All Time: 1,015
