Meta Quest 2 Screen and Lens Assembly Replacement
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Power off your Meta Quest 2: step 1, image 1 of 1
      • Hold the power button for three seconds to fully turn off your headset.
      • You'll hear a power down chime, and the LED next to the power button will turn off.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the facial interface: step 2, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the facial interface: step 2, image 2 of 2
      • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement: step 3, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 3, image 2 of 2
      • Grasp and pull on the top section of the facial interface to unclip it from the headset.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 4, image 1 of 1
      • Remove the facial interface.
      • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: step 5, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: step 5, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: step 5, image 3 of 3
      • Use your fingers to grasp the right strap near the headset.
      • Peel the right strap away from the headset arm to unclip it.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement: step 6, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 6, image 2 of 2
      • Repeat the procedure to peel the left strap away from the arm to unclip it.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the top strap: step 7, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the top strap: step 7, image 2 of 2
      • Separate the hook and loop strip on the top strap.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the head strap: step 8, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the head strap: step 8, image 2 of 2
      • Unthread the top strap from its bracket.
      • Remove the head strap.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim screws: step 9, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim screws: step 9, image 2 of 2
      • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Release the eyepiece trim clips: step 10, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Release the eyepiece trim clips: step 10, image 2 of 2
      • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 11, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 11, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 11, image 3 of 3
      • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
      • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
      • Leave the opening pick in the seam to prevent the clips from reengaging.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement: step 12, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 12, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 12, image 3 of 3
      • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
      • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
      Ask FixBot
    5. Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: step 13, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: step 13, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: step 13, image 3 of 3
      • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
      • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
      • Set the trim down on your work surface, making sure not to strain the cable.
      Ask FixBot
    6. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: step 14, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: step 14, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: step 14, image 3 of 3
      • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
      Ask FixBot
    7. Meta Quest 2 Screen and Lens Assembly Replacement: step 15, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to pull the face sensor cable out of the ZIF connector.
      Ask FixBot
    8. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim: step 16, image 1 of 1
      • Remove the eyepiece trim.
      Ask FixBot
    9. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 17, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 17, image 2 of 2
      • During reassembly:
      • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
      • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
      Ask FixBot
    10. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 18, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 18, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 18, image 3 of 3
      • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
      • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
      • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
      • Use a spudger to press the lock tab down towards the cable to lock it in place.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: step 19, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: step 19, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: step 19, image 3 of 3
      • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
      • One recessed in the top-left corner
      • One recessed in the top-right corner
      • Three along the lower edge
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Release the front cover clips: step 20, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Release the front cover clips: step 20, image 2 of 2
      • The front cover is still held in place by clips along the bottom and side edges.
      • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
      • Pry with the opening pick to release the front cover clips.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 21, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 21, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 21, image 3 of 3
      • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover: step 22, image 1 of 1
      • Remove the front cover.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: step 23, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: step 23, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: step 23, image 3 of 3
      Buy
      • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
      • Lift the antenna connector straight up to disconnect it.
      • Guide the antenna cable out of its metal clip holding it in place.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the battery cable bracket: step 24, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
      • One 4.4 mm‑long screw
      • Two 2.3 mm‑long screws
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 25, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 25, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 25, image 3 of 3
      • Use tweezers or your fingers to grasp the battery cable bracket.
      • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
      • Remove the battery cable bracket.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the battery: step 26, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the battery: step 26, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
      • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: step 27, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: step 27, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: step 27, image 3 of 3
      Buy
      • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the front antenna assembly: step 28, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the front antenna assembly: step 28, image 2 of 2
      • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
      • Four 4.4 mm‑long screws
      • Two 4.8 mm‑long screws
      • Two 10.7 mm‑long screws
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 29, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 29, image 2 of 2
      • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement: step 30, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 30, image 2 of 2
      • Use tweezers to unclip the antenna cable from its metal clip.
      Ask FixBot
    5. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front antenna assembly: step 31, image 1 of 1
      • Remove the front antenna assembly.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the fan: step 32, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the fan: step 32, image 2 of 2
      Buy
      • Use tweezers to grab the fan connector and carefully slide it out of its socket.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the LED flex cable: step 33, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the LED flex cable: step 33, image 2 of 2
      • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the fan assembly: step 34, image 1 of 1
      • Remove the two screws securing the fan assembly to the headset:
      • One 4.4 mm‑long Phillips screw
      • One 3.6 mm‑long Torx T2 screw
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement: step 35, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 35, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 35, image 3 of 3
      • Lift the fan assembly and remove it.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the heat sink: step 36, image 1 of 1
      • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement: step 37, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 37, image 2 of 2
      iFixit Thermal Putty
      $9.95
      Buy
      • Use your fingers to lift the heat sink and remove it.
      • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
      • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of thermal putty or viscous thermal compound (such as K5 Pro) to the processor.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 38, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 38, image 2 of 2
      • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
      • Two speaker connectors
      • Seven ZIF connectors
      • Two press connectors
      • One antenna connector
      • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: step 39, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: step 39, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: step 39, image 3 of 3
      Buy
      • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
      • Lift the connector gently straight up to disconnect it.
      • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 40, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 40, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 40, image 3 of 3
      • Repeat the disconnection procedure for the right speaker connector.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the ZIF socket flex cables: step 41, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the ZIF socket flex cables: step 41, image 2 of 2
      • Use tweezers to gently peel the black tape covering the two top flex cables.
      • Set the tape aside to be reused during reassembly.
      Ask FixBot
    5. Meta Quest 2 Screen and Lens Assembly Replacement: step 42, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 42, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 42, image 3 of 3
      • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
      Ask FixBot
    6. Meta Quest 2 Screen and Lens Assembly Replacement: step 43, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 43, image 2 of 2
      • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
      Ask FixBot
    7. Meta Quest 2 Screen and Lens Assembly Replacement: step 44, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 44, image 2 of 2
      • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
      • Power button and LED board
      • Bottom left camera
      • Bottom right camera
      • Top right camera
      • Face sensor interconnect cable
      • Indicator LED cable
      Ask FixBot
    8. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: step 45, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: step 45, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: step 45, image 3 of 3
      • Use a spudger to pry up and disconnect the display cable.
      Ask FixBot
    9. Meta Quest 2 Screen and Lens Assembly Replacement: step 46, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 46, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 46, image 3 of 3
      • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
      Ask FixBot
    10. Meta Quest 2 Screen and Lens Assembly Replacement: step 47, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 47, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 47, image 3 of 3
      • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
      Ask FixBot
    11. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the motherboard: step 48, image 1 of 1
      • Remove the five screws securing the motherboard to the headset:
      • Four 3.8 mm‑long Phillips screws
      • One 6 mm‑long 3.5 mm hex standoff screw
      Ask FixBot
    12. Meta Quest 2 Screen and Lens Assembly Replacement: step 49, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 49, image 2 of 2
      • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
      • Use a spudger to pry up and separate the motherboard from the headset.
      • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
      Ask FixBot
    13. Meta Quest 2 Screen and Lens Assembly Replacement: step 50, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 50, image 2 of 2
      $9.95
      Buy
      • Remove the motherboard.
      Ask FixBot
    1. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: step 51, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: step 51, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: step 51, image 3 of 3
      Buy
      • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
      • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
      • The camera covers have different alignment cutouts and aren't interchangeable.
      Ask FixBot
    2. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the screen and lens assembly: step 52, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the screen and lens assembly: step 52, image 2 of 2
      • Peel and remove the black tape covering the antenna cable.
      • Set this tape aside to be reused during reassembly.
      Ask FixBot
    3. Meta Quest 2 Screen and Lens Assembly Replacement: step 53, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 53, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 53, image 3 of 3
      • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
      Ask FixBot
    4. Meta Quest 2 Screen and Lens Assembly Replacement: step 54, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 54, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 54, image 3 of 3
      • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
      • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
      Ask FixBot
    5. Meta Quest 2 Screen and Lens Assembly Replacement: step 55, image 1 of 1
      • Repeat the procedure to disconnect the right microphone cable.
      Ask FixBot
    6. Meta Quest 2 Screen and Lens Assembly Replacement: step 56, image 1 of 2 Meta Quest 2 Screen and Lens Assembly Replacement: step 56, image 2 of 2
      • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
      Ask FixBot
    7. Meta Quest 2 Screen and Lens Assembly Replacement: step 57, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 57, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement: step 57, image 3 of 3
      • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
      • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
      • Two 6.5 mm‑long screws
      • Two 7.7 mm‑long screws
      Ask FixBot
    8. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: step 58, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: step 58, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: step 58, image 3 of 3
      • Grasp the screen and lens assembly with your fingers.
      • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
      • Remove the screen and lens assembly.
      Ask FixBot
    9. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 59, image 1 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 59, image 2 of 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: step 59, image 3 of 3
      • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
      • Three cables along the top edge—two flex cables and one LED flex cable
      • Two cables in the top right corner—the battery connector and an antenna cable
      • Two cables along the right edge—an antenna cable and a wide flex cable
      • Two flex cables along the bottom edge
      • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
      • You can use a rubber band to help secure the cables out of the way.
      Ask FixBot
6 other people completed this guide.
Arthur Shi
347,703 Reputation
927 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
5 Guide Comments
안녕하세요~
Meta Quest 2에 단열소재가 적용되어 있는지 문의 드립니다.
단열소재가 있다면 어느정도의 size인지 알고 싶습니다.
답변 부탁 드립니다.
박성철 - Reply Share
I had mine outside for less then a minute and i had a long yellow line Across the screen and i know it would be cheaper to fix it yourself and you having a step by step instructions on how to fix it is the absolute best thing i have seen a console developer do so you doing this probably super helpful to so many people Thank you
Anthony Dugan - Reply Share
If it doesn’t bother you too much, wait until you need to fix something else(i. e. the battery) and replace the screen with it. If it is a big line, then consider replacing it.
Dane Elliott-Dyson - Reply Share
Hello, i need to replace my lcd 'cause sun burned it, whats the name of the "glue" that holds the lcd to his frame?
Felipe (DonF) - Reply Share
I followed every step, but now my controllers won't connect and they keep buzzing. the quest doesn't track my movements neither. I performed a factory reset, and now I only have sound. I only see an image when I try to turn it off, but the images sticks in front of me the pointer doesn't move. I double-checked all internal connections, and everything appears to be correctly connected. Does someone know the problem? Thanks!
Denis Scheldewaert - Reply Share
Past 24 Hours: 10
Past 7 Days: 88
Past 30 Days: 405
All Time: 12,526
