Meta Quest 2 Lower Cameras Replacement
    1. Meta Quest 2 Lower Cameras Replacement, Power off your Meta Quest 2: step 1, image 1 of 1
      • Hold the power button for three seconds to fully turn off your headset.
      • You'll hear a power down chime, and the LED next to the power button will turn off.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Remove the facial interface: step 2, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Remove the facial interface: step 2, image 2 of 2
      • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement: step 3, image 1 of 2 Meta Quest 2 Lower Cameras Replacement: step 3, image 2 of 2
      • Grasp and pull on the top section of the facial interface to unclip it from the headset.
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 4, image 1 of 1
      • Remove the facial interface.
      • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Unclip the side straps: step 5, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Unclip the side straps: step 5, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Unclip the side straps: step 5, image 3 of 3
      • Use your fingers to grasp the right strap near the headset.
      • Peel the right strap away from the headset arm to unclip it.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement: step 6, image 1 of 2 Meta Quest 2 Lower Cameras Replacement: step 6, image 2 of 2
      • Repeat the procedure to peel the left strap away from the arm to unclip it.
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement, Remove the top strap: step 7, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Remove the top strap: step 7, image 2 of 2
      • Separate the hook and loop strip on the top strap.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement, Remove the head strap: step 8, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Remove the head strap: step 8, image 2 of 2
      • Unthread the top strap from its bracket.
      • Remove the head strap.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Remove the eyepiece trim screws: step 9, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Remove the eyepiece trim screws: step 9, image 2 of 2
      • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement, Release the eyepiece trim clips: step 10, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Release the eyepiece trim clips: step 10, image 2 of 2
      • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 11, image 1 of 3 Meta Quest 2 Lower Cameras Replacement: step 11, image 2 of 3 Meta Quest 2 Lower Cameras Replacement: step 11, image 3 of 3
      • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
      • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
      • Leave the opening pick in the seam to prevent the clips from reengaging.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement: step 12, image 1 of 3 Meta Quest 2 Lower Cameras Replacement: step 12, image 2 of 3 Meta Quest 2 Lower Cameras Replacement: step 12, image 3 of 3
      • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
      • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
      Ask FixBot
    5. Meta Quest 2 Lower Cameras Replacement, Reposition the eyepiece trim: step 13, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Reposition the eyepiece trim: step 13, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Reposition the eyepiece trim: step 13, image 3 of 3
      • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
      • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
      • Set the trim down on your work surface, making sure not to strain the cable.
      Ask FixBot
    6. Meta Quest 2 Lower Cameras Replacement, Disconnect the face sensor: step 14, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the face sensor: step 14, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the face sensor: step 14, image 3 of 3
      • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
      Ask FixBot
    7. Meta Quest 2 Lower Cameras Replacement: step 15, image 1 of 2 Meta Quest 2 Lower Cameras Replacement: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to pull the face sensor cable out of the ZIF connector.
      Ask FixBot
    8. Meta Quest 2 Lower Cameras Replacement, Remove the eyepiece trim: step 16, image 1 of 1
      • Remove the eyepiece trim.
      Ask FixBot
    9. Meta Quest 2 Lower Cameras Replacement, Reassembly note: step 17, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Reassembly note: step 17, image 2 of 2
      • During reassembly:
      • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
      • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
      Ask FixBot
    10. Meta Quest 2 Lower Cameras Replacement, Reassembly note: step 18, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Reassembly note: step 18, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Reassembly note: step 18, image 3 of 3
      • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
      • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
      • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
      • Use a spudger to press the lock tab down towards the cable to lock it in place.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Remove the front cover screws: step 19, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Remove the front cover screws: step 19, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Remove the front cover screws: step 19, image 3 of 3
      • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
      • One recessed in the top-left corner
      • One recessed in the top-right corner
      • Three along the lower edge
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement, Release the front cover clips: step 20, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Release the front cover clips: step 20, image 2 of 2
      • The front cover is still held in place by clips along the bottom and side edges.
      • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
      • Pry with the opening pick to release the front cover clips.
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 21, image 1 of 3 Meta Quest 2 Lower Cameras Replacement: step 21, image 2 of 3 Meta Quest 2 Lower Cameras Replacement: step 21, image 3 of 3
      • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement, Remove the front cover: step 22, image 1 of 1
      • Remove the front cover.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Disconnect the top right antenna: step 23, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the top right antenna: step 23, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the top right antenna: step 23, image 3 of 3
      Buy
      • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
      • Lift the antenna connector straight up to disconnect it.
      • Guide the antenna cable out of its metal clip holding it in place.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement, Remove the battery cable bracket: step 24, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
      • One 4.4 mm‑long screw
      • Two 2.3 mm‑long screws
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 25, image 1 of 3 Meta Quest 2 Lower Cameras Replacement: step 25, image 2 of 3 Meta Quest 2 Lower Cameras Replacement: step 25, image 3 of 3
      • Use tweezers or your fingers to grasp the battery cable bracket.
      • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
      • Remove the battery cable bracket.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement, Disconnect the battery: step 26, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Disconnect the battery: step 26, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
      • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Disconnect the antenna: step 27, image 1 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the antenna: step 27, image 2 of 3 Meta Quest 2 Lower Cameras Replacement, Disconnect the antenna: step 27, image 3 of 3
      Buy
      • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement, Loosen the front antenna assembly: step 28, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Loosen the front antenna assembly: step 28, image 2 of 2
      • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
      • Four 4.4 mm‑long screws
      • Two 4.8 mm‑long screws
      • Two 10.7 mm‑long screws
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 29, image 1 of 2 Meta Quest 2 Lower Cameras Replacement: step 29, image 2 of 2
      • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement: step 30, image 1 of 2 Meta Quest 2 Lower Cameras Replacement: step 30, image 2 of 2
      • Use tweezers to unclip the antenna cable from its metal clip.
      Ask FixBot
    5. Meta Quest 2 Lower Cameras Replacement, Remove the front antenna assembly: step 31, image 1 of 1
      • Remove the front antenna assembly.
      Ask FixBot
    1. Meta Quest 2 Lower Cameras Replacement, Disconnect the lower camera: step 32, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Disconnect the lower camera: step 32, image 2 of 2
      • Use a spudger to pry up and disconnect the lower camera connector.
      Ask FixBot
    2. Meta Quest 2 Lower Cameras Replacement, Loosen the lower camera: step 33, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Loosen the lower camera: step 33, image 2 of 2
      • Slide an opening pick under the camera cable to loosen it from the headset.
      Ask FixBot
    3. Meta Quest 2 Lower Cameras Replacement: step 34, image 1 of 1
      • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the camera.
      Ask FixBot
    4. Meta Quest 2 Lower Cameras Replacement, Remove the camera: step 35, image 1 of 2 Meta Quest 2 Lower Cameras Replacement, Remove the camera: step 35, image 2 of 2
      iFixit Thermal Putty
      $9.95
      Buy
      • Lift and remove the lower camera.
      • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of thermal putty or viscous thermal compound (such as K5 Pro) to the back of the camera.
      Ask FixBot
3 other people completed this guide.
Arthur Shi
347,712 Reputation
927 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 114
All Time: 3,512
