Meta Quest 2 Head Strap Replacement
    1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: step 1, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the facial interface: step 1, image 2 of 2
      • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
      Ask FixBot
    2. Meta Quest 2 Head Strap Replacement: step 2, image 1 of 2 Meta Quest 2 Head Strap Replacement: step 2, image 2 of 2
      • Grasp and pull on the top section of the facial interface to unclip it from the headset.
      Ask FixBot
    3. Meta Quest 2 Head Strap Replacement: step 3, image 1 of 1
      • Remove the facial interface.
      • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
      Ask FixBot
    1. Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 1 of 3 Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 2 of 3 Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 3 of 3
      • Use your fingers to grasp the right strap near the headset.
      • Peel the right strap away from the headset arm to unclip it.
      Ask FixBot
    2. Meta Quest 2 Head Strap Replacement: step 5, image 1 of 2 Meta Quest 2 Head Strap Replacement: step 5, image 2 of 2
      • Repeat the procedure to peel the left strap away from the arm to unclip it.
      Ask FixBot
    3. Meta Quest 2 Head Strap Replacement, Remove the top strap: step 6, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the top strap: step 6, image 2 of 2
      • Separate the hook and loop strip on the top strap.
      Ask FixBot
    4. Meta Quest 2 Head Strap Replacement, Remove the head strap: step 7, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the head strap: step 7, image 2 of 2
      • Unthread the top strap from its bracket.
      • Remove the head strap.
      Ask FixBot
19 other people completed this guide.
Arthur Shi
347,646 Reputation
927 Guides authored
1 Guide Comment
Merci pour ce tuto qui m'a permis de nettoyer la sangle. En revanche comme elle s'est décollée de ses deux supports, il a fallu la recoller.
Max Grammare - Reply Share
Past 24 Hours: 20
Past 7 Days: 140
Past 30 Days: 657
All Time: 49,494
