Meta Quest 2 Eyepiece Trim Replacement
  1. Meta Quest 2 Eyepiece Trim Replacement, Power off your Meta Quest 2: step 1, image 1 of 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
    Ask FixBot
  2. Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: step 2, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: step 2, image 2 of 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
    Ask FixBot
  3. Meta Quest 2 Eyepiece Trim Replacement: step 3, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement: step 3, image 2 of 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
    Ask FixBot
  4. Meta Quest 2 Eyepiece Trim Replacement: step 4, image 1 of 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
    Ask FixBot
  5. Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: step 5, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: step 5, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: step 5, image 3 of 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
    Ask FixBot
  6. Meta Quest 2 Eyepiece Trim Replacement: step 6, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement: step 6, image 2 of 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
    Ask FixBot
  7. Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: step 7, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: step 7, image 2 of 2
    • Separate the hook and loop strip on the top strap.
    Ask FixBot
  8. Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: step 8, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: step 8, image 2 of 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
    Ask FixBot
  9. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: step 9, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: step 9, image 2 of 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
    Ask FixBot
  10. Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: step 10, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: step 10, image 2 of 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
    Ask FixBot
  11. Meta Quest 2 Eyepiece Trim Replacement: step 11, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement: step 11, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement: step 11, image 3 of 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
    Ask FixBot
  12. Meta Quest 2 Eyepiece Trim Replacement: step 12, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement: step 12, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement: step 12, image 3 of 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
    Ask FixBot
  13. Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: step 13, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: step 13, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: step 13, image 3 of 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
    Ask FixBot
  14. Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: step 14, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: step 14, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: step 14, image 3 of 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
    Ask FixBot
  15. Meta Quest 2 Eyepiece Trim Replacement: step 15, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
    Ask FixBot
  16. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim: step 16, image 1 of 1
    • Remove the eyepiece trim.
    Ask FixBot
  17. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: step 17, image 1 of 2 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: step 17, image 2 of 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
    Ask FixBot
  18. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: step 18, image 1 of 3 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: step 18, image 2 of 3 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: step 18, image 3 of 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
    Ask FixBot
2 other people completed this guide.
Arthur Shi
343,592 Reputation
915 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 66
All Time: 2,431
