Meta Quest 2 Controller Thumbgrip Replacement
    1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: step 1, image 1 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: step 1, image 2 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: step 1, image 3 of 3
      • Use your fingers to slide the battery cover down towards the strap end of the controller.
      • Remove the battery cover.
      • If you're taking the controller apart for repairs, remove the batteries in the controller.
      Ask FixBot
    1. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the faceplate adhesive: step 2, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
      Ask FixBot
    2. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: step 3, image 1 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: step 3, image 2 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: step 3, image 3 of 3
      • The controller faceplate is secured with adhesive and three friction pegs.
      • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
      • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
      • Slide the opening tool to the base of the ring shell to loosen the adhesive.
      Ask FixBot
    3. Meta Quest 2 Controller Thumbgrip Replacement: step 4, image 1 of 2 Meta Quest 2 Controller Thumbgrip Replacement: step 4, image 2 of 2
      • Use an opening tool to pry up on the seam to loosen the first friction peg.
      Ask FixBot
    4. Meta Quest 2 Controller Thumbgrip Replacement: step 5, image 1 of 2 Meta Quest 2 Controller Thumbgrip Replacement: step 5, image 2 of 2
      • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
      • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
      Ask FixBot
    5. Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: step 6, image 1 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: step 6, image 2 of 3 Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: step 6, image 3 of 3
      • Remove the controller faceplate.
      • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
      Ask FixBot
    1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: step 7, image 1 of 2 Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: step 7, image 2 of 2
      • Use your fingers to pull the thumbgrip straight off of the thumbstick and remove it.
      Ask FixBot
2 other people completed this guide.
Arthur Shi
347,718 Reputation
927 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 102
All Time: 2,736
