Up to 20% off select tools
Meta Quest 2 Controller Ring Shell Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
27
Past 7 Days:
111
Past 30 Days:
298
All Time:
8,589
Comments: 11
10 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove and replace a cracked controller ring shell for your Meta Quest 2 controller.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
    1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: step 1, image 1 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: step 1, image 2 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: step 1, image 3 of 3
      • Use your fingers to slide the battery cover down towards the strap end of the controller.
      • Remove the battery cover.
      • If you're taking the controller apart for repairs, remove the batteries in the controller.
      Ask FixBot
    1. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: step 2, image 1 of 2 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: step 2, image 2 of 2
      • Use your fingers to grasp the wrist strap near the anchor peg.
      • Lift the wrist strap anchor peg straight out of its recess.
      • Remove the wrist strap.
      Ask FixBot
    1. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: step 3, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
      Ask FixBot
    2. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: step 4, image 1 of 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: step 4, image 2 of 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: step 4, image 3 of 3
      • The controller faceplate is secured with adhesive and three friction pegs.
      • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
      • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
      • Slide the opening tool to the base of the ring shell to loosen the adhesive.
      Ask FixBot
    3. Meta Quest 2 Controller Ring Shell Replacement: step 5, image 1 of 2 Meta Quest 2 Controller Ring Shell Replacement: step 5, image 2 of 2
      • Use an opening tool to pry up on the seam to loosen the first friction peg.
      Ask FixBot
    4. Meta Quest 2 Controller Ring Shell Replacement: step 6, image 1 of 2 Meta Quest 2 Controller Ring Shell Replacement: step 6, image 2 of 2
      • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
      • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
      Ask FixBot
    5. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: step 7, image 1 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: step 7, image 2 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: step 7, image 3 of 3
      • Remove the controller faceplate.
      • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
      Ask FixBot
    1. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: step 8, image 1 of 2 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: step 8, image 2 of 2
      • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
      • Two 4.7 mm‑long screws
      • Two 5.9 mm‑long screws
      Ask FixBot
    2. Meta Quest 2 Controller Ring Shell Replacement: step 9, image 1 of 2 Meta Quest 2 Controller Ring Shell Replacement: step 9, image 2 of 2
      • Press the point of a spudger firmly against the white alignment square to release the ring shell.
      Ask FixBot
    3. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: step 10, image 1 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: step 10, image 2 of 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: step 10, image 3 of 3
      • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
      • Gently lift the ring shell up and away from the controller to unclip it from the controller.
      • Remove the controller ring shell.
      Ask FixBot
2 other people completed this guide.
Arthur Shi
354,367 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - Reply Share
Past 24 Hours: 27
Past 7 Days: 111
Past 30 Days: 298
All Time: 8,589
