Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide shows how to remove and replace the controller board for your Meta Quest 2 controller.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
Use your fingers to slide the battery cover down towards the strap end of the controller.
Remove the battery cover.
Use your fingers to grasp the wrist strap near the anchor peg.
Lift the wrist strap anchor peg straight out of its recess.
Remove the wrist strap.
Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
The controller faceplate is secured with adhesive and three friction pegs.
Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
Slide the opening tool to the base of the ring shell to loosen the adhesive.
Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
Two 4.7 mm‑long screws
Two 5.9 mm‑long screws
Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
Gently lift the ring shell up and away from the controller to unclip it from the controller.
Remove the controller ring shell.
Use a Torx T5 driver to remove the five screws:
One 11.5 mm‑long screw
Three 5.9 mm‑long screws
One 18.2 mm‑long screw
Tool used on this step:Tweezers$4.99
Use tweezers and your fingers to peel the battery information label out from the battery compartment.
Use a Torx T5 driver to remove the four 5.9 mm‑long screws securing the side shell to the controller:
Three screws inside the battery compartment
One screw near the corner of the battery compartment
Guide the looped part of the side shell through the screw post gap.
Remove the side shell.
Spread the screw post wide enough to loop the side shell back around it.
Be careful not to pinch the antenna cable or the tracking flex cable as you reposition the side shell.
Use a spudger or an opening pick to gently pry the shell from the battery compartment side first.
Once it pops open, turn the controller over to remove the front shell.
Use a driver bit (such as the Torx T5) or the point of a spudger to push the front trigger pin out from the side shown. Pushing from the opposite side can cause the pin to rip the sensor cable.
Use a clean fingernail or tweezers to flip up the ZIF socket's lock bar securing the outer tracking flex cable.
Insert one arm of a pair of tweezers under the metal neck of the antenna cable.
Pry straight up to disconnect the antenna from the controller board.
Gently pull the antenna to unclip it from its grounding clip.
Use your fingers to twist the battery shell slightly so that its edge near the thumbstick clicks out of place.
Use a Torx T5 driver to remove the four 7.5 mm‑long screws securing the controller board.
Use your fingers to lift the controller board out of the shell and remove it.
2 other people completed this guide.
2 Guide Comments
Where can I purchase a controller board for my Meta Quest 2 right controller?
How can I reattach the ZIF socket to the circuit board?
