Mercedes W123 Radiator Hose Replacement
  1. Mercedes W123 Radiator Hose Replacement, Radiator Hose: step 1, image 1 of 1
    • Begin by draining your radiator of coolant as [invalid guide link]. You will not need to drain the block for this process.
    • As always, never work on your coolant system when it is hot. This is very very dangerous.
    Ask FixBot
  2. Mercedes W123 Radiator Hose Replacement: step 2, image 1 of 2 Mercedes W123 Radiator Hose Replacement: step 2, image 2 of 2
    • Find your upper coolant hose connection at the upper driver's side of the radiator.
    • Loosen the hose clamp on this end of the hose.
    Ask FixBot
  3. Mercedes W123 Radiator Hose Replacement: step 3, image 1 of 1
    • Follow this hose to the top of the engine block, where it enters the thermostat housing.
    Ask FixBot
  4. Mercedes W123 Radiator Hose Replacement: step 4, image 1 of 1
    • Then use a hose clamp removal hook or other appropriate tools to work around under the edge of the hose. This will help break them free; they often stick to the necks they attach to over time.
    • Pull the hose off fully on both ends.
    Ask FixBot
  5. Mercedes W123 Radiator Hose Replacement: step 5, image 1 of 1
    • Continue by loosening the clamp on the lower radiator hose where it connects to the thermostat housing.
    Ask FixBot
  6. Mercedes W123 Radiator Hose Replacement: step 6, image 1 of 1
    • Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
    • Remove the hose in the same manner you did the upper hose.
    • Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
    • Finish by filling the system with coolant and bleeding the system as [invalid guide link]
    Ask FixBot
5 other people completed this guide.
Nicolas Siemsen
40,499 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
334 Members
1,694 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 52
All Time: 7,324
