Mercedes W123 Hazard Swich Disassembly
  1. Mercedes W123 Hazard Swich Disassembly, Mercedes W123 Hazard Swich Disassembly: step 1, image 1 of 1
    • First you must remove the switch for it revises the other guides of this page
    Ask FixBot
  2. Mercedes W123 Hazard Swich Disassembly: step 2, image 1 of 1
    • Once removed you must remove the bulb from the switch, this goes under pressure can help you with a small pliers.
    Ask FixBot
  3. Mercedes W123 Hazard Swich Disassembly: step 3, image 1 of 1
    • You must insert a blade or flat (thin) screwdriver into the existing slot in the base between the two small clasps, and gently pry
    Ask FixBot
  4. Mercedes W123 Hazard Swich Disassembly: step 4, image 1 of 2 Mercedes W123 Hazard Swich Disassembly: step 4, image 2 of 2
    • Now you have in your hands the piece with contacts to clean, be careful that inside the body are 3 pieces (1 plastic and two metal) and two small springs that can escape
    Ask FixBot
  5. Mercedes W123 Hazard Swich Disassembly: step 5, image 1 of 2 Mercedes W123 Hazard Swich Disassembly: step 5, image 2 of 2
    • This step is optional, in case you have to change the red cover, or repair it.
    • With the thin blade screwdriver, you must pry between the red shaft and the black plastic CAUTION! Do not insert the screwdriver too much, because when leveraging you can break the legs of the red switch, which activates the mechanism
    Ask FixBot
  6. Mercedes W123 Hazard Swich Disassembly: step 6, image 1 of 3 Mercedes W123 Hazard Swich Disassembly: step 6, image 2 of 3 Mercedes W123 Hazard Swich Disassembly: step 6, image 3 of 3
    • Once the contacts are clean, we put back together
    • First we put the two springs in their spaces.
    • Then we put the contacts on the springs, to finally take the assembly and place it inside the body of the switch
    Ask FixBot
  7. Mercedes W123 Hazard Swich Disassembly: step 7, image 1 of 2 Mercedes W123 Hazard Swich Disassembly: step 7, image 2 of 2
    • finally we take the contact panel and place it in the switch body, we press until it clicks! Be careful to place the pieces so that the hole for the vial is aligned.
    • Finally if you removed the red switch enter again until you click! The triangle icon should go to the side where the ampule is.
    Ask FixBot
For reassembling your device, follow these instructions in the reverse order.
6 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos
993 Reputation
4 Guides authored
2 Guide Comments
Hey, thanks for the guide…I'm wondering about something, that maybe you could help me with… I love the look of the older ,pre 1980 hazard switch, is it possible to change the newer style switch, to the older bigger switch…even just to change the cover, to make it look like the old one would be fine…..What do you think?…thañks…Michael
Michael Roche - Reply Share
Hellow there, the older switch is diferent, it works by pushing it down to activate it, rahter than pivoting like the newer style, I thing the easy solution is to massure the old style switch and bore the center consol to make it fit, the console is easy to remove, and its all plastic, or wood, so shouldent be hard to bore the hole. The switch stays in place by pressure
Carlos - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 4,958
