Up to 20% off select tools
Mercedes W123 Fuel Return Line Replacement
Views: 19K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
146
All Time:
19,347
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Brittle, old injector return lines can leave you stranded when they split and leak fuel all over your engine.
You'll need to keep an even closer eye on them if you run biodiesel. If you use 99% biodiesel they may only last a year. Biodiesel literally dissolves rubber!
Learn to replace them now, and keep some spare in your trunk for emergencies.
    1. Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: step 1, image 1 of 3 Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: step 1, image 2 of 3 Mercedes W123 Fuel Return Line Replacement, Fuel Return Line: step 1, image 3 of 3
      • As shown here, the injector return lines go from one injector to the next.
      • And then they stop with a plug at the rearmost injector, closest to the firewall.
      Ask FixBot
    2. Mercedes W123 Fuel Return Line Replacement: step 2, image 1 of 1
      • The lines should simply pull off of the injector nipples.
      • These lines were fairly stiff, but not brittle yet. However, it's a good time to replace them. Once they become brittle the can become very hard to remove. They will break off at the nipple and they will need to be cut off with a razor blade, very carefully, to avoid scoring the metal nipples.
      Ask FixBot
    3. Mercedes W123 Fuel Return Line Replacement: step 3, image 1 of 1
      • Notice how much larger the opening at the end of the old injector return line, left, is than the one on the right, which is new.
      • As the lines become brittle they seal less well at the nipples due to this.
      • Now, cut a length of new line to approximately the same length as the old line. You can err on the side of being a bit too long to make it easier to install.
      Ask FixBot
    4. Mercedes W123 Fuel Return Line Replacement: step 4, image 1 of 2 Mercedes W123 Fuel Return Line Replacement: step 4, image 2 of 2
      • Installation is simply the reverse; push the new line down on to the nipples on the injector.
      • It can help to do just one at a time, so you don't mix up which line goes where.
      • Another helpful tip is to use a small needle nose plier to start the line on the injector nipple when the space if too tight for your fingers.
      Ask FixBot
    5. Mercedes W123 Fuel Return Line Replacement: step 5, image 1 of 2 Mercedes W123 Fuel Return Line Replacement: step 5, image 2 of 2
      • Don't forget to replace the long piece of line that runs from the front-most injector to the secondary fuel filter housing.
      • It starts here at the front-most injector.
      • And connects here at the filter housing.
      Ask FixBot
    6. Mercedes W123 Fuel Return Line Replacement: step 6, image 1 of 3 Mercedes W123 Fuel Return Line Replacement: step 6, image 2 of 3 Mercedes W123 Fuel Return Line Replacement: step 6, image 3 of 3
      • Also, be sure to change the plug on the rear-most injector nipple.
      • The one removed from this car was a braided line with a metal plug in it.
      • The one being installed is a special rubber plug that only has one opening.
      • You can also make one yourself, using a short piece of regular return line and a tightly fitting screw that can be securely inserted in one end of the short line.
      Ask FixBot
Once you're done priming, start the engine and let it run momentarily to ensure it's primed properly.
11 other people completed this guide.
Author
with
Nicolas Siemsen
40,598 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
3 Guide Comments
What size diameter and fuel line material should I get as a replacement?
Simon Walter-Hansen - Reply Share
The lines are available in Viton as well, which is biodiesel compatible:
617/616: https://www.amazon.com/dp/B07L6SS6B6
603/602/601: https://www.amazon.com/dp/B07L6QTYS1
Will MacNeill - Reply Share
I redid my lines after paying a shop here in Granbury,TX 1400.00 to replace my fuel injection system..thier tech told me when I picked my 83 Benz 300D Turbo up..that he had no idea what he was doing..after the fact..he put plain rubber hoses on her that melted on the way home.. I'm a 60 yr old female whose worked on cars for 50yrs, never have I seen such poor service..as this shop.
Catherine - Reply Share
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 146
All Time: 19,347
