Mercedes W123 Fuel Primer Pump Replacement
  1. Mercedes W123 Fuel Primer Pump Replacement, Fuel Primer Pump: step 1, image 1 of 1
    • Seen here is the original primer pump on this 1979 300CD. It is an older style that has become prone to leaking after all these years. We are going to replace it with an updated style by Bosch.
    Ask FixBot
  2. Mercedes W123 Fuel Primer Pump Replacement: step 2, image 1 of 1
    • Note the fuel in the cavity on top of the pump. This pump was definitely leaking. Most of them do these days.
    Ask FixBot
  3. Mercedes W123 Fuel Primer Pump Replacement: step 3, image 1 of 2 Mercedes W123 Fuel Primer Pump Replacement: step 3, image 2 of 2
    • Removing the old primer pump is simply a matter of finding the proper wrench to either grab the flat sides at the base of the pump, or using a vice grip to grab the body of the pump. An offset wrench like pictured can be very helpful. Since the pump is being replaced it doesn't matter too much if the vice grips damage the pump.
    • Note that clearance can be a bit tight down by the primer due to fuel and power steering fluid lines in the area. However, if you're patient, you'll find a way to get the tools on and turn off the pump.
    • Note that there seems to be variation in the size of wrench these primer pumps take. The offset wrench I have is a 19mm which worked on a pump on another car, but was too small for this car. So I used vice grips.
    Ask FixBot
  4. Mercedes W123 Fuel Primer Pump Replacement: step 4, image 1 of 2 Mercedes W123 Fuel Primer Pump Replacement: step 4, image 2 of 2
    • Under the old primer pump will be a copper crush washer. This must be removed before installing the new pump as you'll be installing a new crush washer. Use a small flat blade screw driver to gently push and pry on this washer to remove it.
    Ask FixBot
  5. Mercedes W123 Fuel Primer Pump Replacement: step 5, image 1 of 2 Mercedes W123 Fuel Primer Pump Replacement: step 5, image 2 of 2
    • Here is the old primer pump removed from the car. You can see the minimal damage that the vice grips did to the body of it. Also, in the second picture, you can see how wet, discolored, and dirty the pump knob is. This is from leaking fuel.
    Ask FixBot
  6. Mercedes W123 Fuel Primer Pump Replacement: step 6, image 1 of 2 Mercedes W123 Fuel Primer Pump Replacement: step 6, image 2 of 2
    • Here is the updated style pump. It uses a simple plunger and should prove simple and reliable to use.
    • The threaded end of the primer pump is protected in the box by a yellow plastic cap. Underneath the cap is the new copper crush washer. Be sure not to drop it and let it roll away!
    Ask FixBot
  7. Mercedes W123 Fuel Primer Pump Replacement: step 7, image 1 of 1
    • Carefully use a shop towel to wipe any dirt out and away from the opening in the lift pump, then install the new crush washer.
    Ask FixBot
  8. Mercedes W123 Fuel Primer Pump Replacement: step 8, image 1 of 1
    • Now screw the new primer pump in by hand as far as you can, then use a wrench (the new ones take a 17mm) to snug it down. There is no need to wrench on it really heavily, just turn it until you feel resistance as the crush washer deforms to create a seal under the pump.
    Ask FixBot
When you've finished run your engine and check for leaks. If it is leaking at the base, where the pump screws in, the crush washer is not fully crushed. Tighten it down a little more.
16 other people completed this guide.
Nicolas Siemsen
40,499 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
334 Members
1,694 Guides authored
4 Guide Comments
Unfortunately, wasn't much help with my 83 300D, because the pump and fittings are reversed. Which makes it very difficult to get to the pump to tighten it down, with the brass fittings in the way. So if your setup doesn't look like the pictures above, you're going to have to do some extra work to get it done.
jamesrasbeary - Reply Share
Yes, mine too… Most odd - a lot more work getting it sorted. Thanks for the write up though.
Bruce Wright - Reply Share
Hi,
I lost the little plastic piece goes under the primer pump, and therefore the pump doesn’t work properly. What is this piece, and where can I find a new one?
Nicholas Otten - Reply Share
Mine is different as well, only 2 nuts/ studs holding the body on most seem to have 3. My 2 brass fittings also make it more difficult.
Shaun James - Reply Share
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 237
All Time: 23,497
