Mercedes W123 Battery Ground Cable Replacement
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: step 1, image 1 of 2 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: step 1, image 2 of 2
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
    Ask FixBot
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: step 2, image 1 of 1
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
    Ask FixBot
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: step 3, image 1 of 2 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: step 3, image 2 of 2
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
    Ask FixBot
  4. Mercedes W123 Battery Ground Cable Replacement: step 4, image 1 of 1
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
    Ask FixBot
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
12 other people completed this guide.
Nicolas Siemsen
40,499 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
334 Members
1,694 Guides authored
2 Guide Comments
Problem de cable moins
Hamateegandawel@gmail.com - Reply Share
Problem de masse cable du batterie moins voiture Mercedes binz c180
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 61
All Time: 10,667
