Mercedes W123 Ash Tray Replacement
Views: 14K
View statistics:
Past 24 Hours:
8
Past 7 Days:
29
Past 30 Days:
149
All Time:
14,145
Comments: 5
5 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Removing the ash tray on a W123 is easy, but the method is not immediately obvious. This guide will show you how. Also, you'll learn how to remove the backing plate that the ash tray sits in in case you need to get greater access to the area behind it.
Tools
    1. Mercedes W123 Ash Tray Replacement, Ash Tray: step 1, image 1 of 1
      • With the car turned off, engage the parking brake. Failure to do this could be dangerous as you need to move the gear lever out of park to continue this guide.
      • Then move the shift lever all the way back in to L to give you room to work.
      Ask FixBot
    2. Mercedes W123 Ash Tray Replacement: step 2, image 1 of 1
      • Now pull the ash tray open as you normally would.
      Ask FixBot
    3. Mercedes W123 Ash Tray Replacement: step 3, image 1 of 1
      • Now push down on the tab that is at the center of the ash tray assembly.
      Ask FixBot
    4. Mercedes W123 Ash Tray Replacement: step 4, image 1 of 1
      • While continuing to hold down the tab you can pull the ash tray forward, and out of the opening it sits in.
      Ask FixBot
    5. Mercedes W123 Ash Tray Replacement: step 5, image 1 of 1
      • If you want to remove the entire assembly including the bracket that the ash tray rests in you can proceed to remove the two screws that hold it to the center console.
      Ask FixBot
14 other people completed this guide.
Nicolas Siemsen
40,598 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,294 Guides authored
5 Guide Comments
What would be the purpose of removing ashtray ?
Andrea Summadre - Reply Share
It provides access to the portion of the center console behind the ash tray. There is wiring back there. It can also help with the removal of the shift gate panel.
Nicolas Siemsen - Reply Share
Removal of ashtray is also necessary to access the lamp which illuminates the cavity. After taking ashtray out, remove two Philips (+) screws, then separate metal cover from plastic housing. Next to the lighter housing is light socket. It holds a 12 volt, 2 watt, T2 bayonet base, #1272 lamp. Push, then twist lamp to remove. Clean copper terminal at side of socket as well as moving contact on side of ashtray housing. This lamp is same type as used for automatic shift indicator. This is one of the most overlooked lamps in a W123 chassis. Tip: while metal cover is removed, clean and scrub ashtray, it is much easier to access this way.
analogcd - Reply Share
Hello Nicolas, How about removing the radio, is there a latch to be released from the ash tray compartment?
chirolob - Reply Share
Bonjour , connaissais vous le probleme sur le selecteur de vitesse d'une clc 200 cdi w203.
j'ai ce problème de 2 mois , j'ai même changer le sélecteur et toujours pareil nil reste bloquer en 2e .
merci pour votre réponse si vous connaissais le problème.
Carlos - Reply Share
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 149
All Time: 14,145
