Mercedes Sprinter Door Magnets Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
83
All Time:
223
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hey everyone, very simple guide here for you.
The old magnets that keep the doors fully open had disintegrated over the years. I bought brand new ones to replace them.
It was as simple as removing the old ones with a grip tool due to how bad they had got. Normally you would use a larger grip tool or your hands if you're strong enough.
What you can also do is go to the inside and release the tension on the screws to make this easier.
Once this is off, simply clean around the area and inside the hole and remove and residue.
You can now attach the new magnet by screwing it in place and then tightening the screws on the inside.
Video Overview
    1. Mercedes Sprinter Door Magnets Replacement, REMOVE OLD MAGNET: step 1, image 1 of 1
      • Remove the old Magnet using some grips or your hands. Please wear suitable PPE.
      Ask FixBot
    2. Mercedes Sprinter Door Magnets Replacement, CLEAN THE HOLE: step 2, image 1 of 1
      • Clean the hole. Ensure there is no residue left over. You can do this with simple cleaning products, but if the residue is more difficult, you can use Panel Wipe. You can also use DPF, but use that at your own risk as it can damage your paint. Always test patch before using chemicals.
      Ask FixBot
    3. Mercedes Sprinter Door Magnets Replacement, NEW MAGNET: step 3, image 1 of 1
      • Go to attach your new door magnet into the hole, ensuring the screw hole lines up properly. Do not force it in otherwise you may thread the hole.
      Ask FixBot
    4. Mercedes Sprinter Door Magnets Replacement, TIGHTEN: step 4, image 1 of 1
      • Begin to tighten to the magnet, this will squeak a lot and seem like it is tight due to the rubber against the metal, but it is not. But do not over tighten this.
      Ask FixBot
    5. Mercedes Sprinter Door Magnets Replacement, SEAL IT: step 5, image 1 of 1
      • Once this is complete, you should see a nice seal all around the rubber, this will ensure no water can get inside the vehicle, this is very important.
      Ask FixBot
    6. Mercedes Sprinter Door Magnets Replacement, TEST IT: step 6, image 1 of 1
      • Ensure you have done a test of everything to make sure it is all in working order and there you have it!
      Ask FixBot
Charlie Vanstone
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 83
All Time: 223
