Merangue Steel 3-Hole Punch Head Replacement
    1. Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 3 of 3
      • Tilt the hole puncher on its back.
      • Use a flathead screwdriver to remove the three screws.
      Ask FixBot
    2. Merangue Steel 3-Hole Punch Head Replacement: step 2, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 2, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 2, image 3 of 3
      • Use your finger to slide the punch head out towards the opening (right in this case).
      • Remove the punch head from the opening and set it aside.
      • Repeat this step with the other punch heads.
      Ask FixBot
    3. Merangue Steel 3-Hole Punch Head Replacement: step 3, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 3, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 3, image 3 of 3
      • Take your replacement hole punch and push it into the opening.
      • Slide the hole punch to your desired alignment in my case, left).
      • Make sure the hole punch is properly aligned (the hole at the back should point directly at the ceiling).
      Ask FixBot
    4. Merangue Steel 3-Hole Punch Head Replacement: step 4, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 4, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 4, image 3 of 3
      • Use your fingers to screw one of the screws into the hole on the back of the punch head.
      • The screw can be a bit difficult to align so be patient and don't rush.
      • Take your flat head screwdriver and tighten the screw.
      • Repeat these steps for the other punch heads.
      Ask FixBot
Finish Line
Noah Dela Calzada
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 882
