Memorex 2Xtreme MP3830-01 Function Buttons Replacement
  1. Memorex 2Xtreme MP3830-01 Function Buttons Replacement, Remove Bottom Shell: step 1, image 1 of 1
    • Before disassembly, ensure that the boombox is powered off, unplugged and any batteries have been removed from the device.
    • Begin by turning the boombox over so that the bottom is facing up.
    • When turning the boombox over, the antenna will be pointing down. Take care that the antenna is not damaged when opening the device.
    • Your boombox will have a total of 12 Phillips screws on the bottom. The location of the screws needed to remove the bottom panel are circled in red in the image to the left.
    • Remove the 12 screws with a Phillips head screwdriver on the bottom panel.
    • One screw, in the upper left corner, does not need to be removed to disassemble the device. This screw is for the antenna.
    Ask FixBot
  2. Memorex 2Xtreme MP3830-01 Function Buttons Replacement: step 2, image 1 of 1
    • With all 12 screws removed, it is possible to detach the plastic bottom cover from the top half of the boombox.
    • Push the bottom shell back slightly before pulling it up. The plastic bottom will lift up directly but there is a lip that fits under the black handle that must first be exposed, as seen in the image on the left.
    • The boombox's antenna must be straight in order for the bottom cover to be pulled up.
    • Several wires run between the bottom half and top half of the boombox. Take care not to damage or otherwise tear the wiring when opening the device.
    Ask FixBot
  3. Memorex 2Xtreme MP3830-01 Function Buttons Replacement: step 3, image 1 of 1
    • The boombox should now be in two separate pieces, connected only by two wires.
    • Disconnect the red and black wires by gently grasping its white plastic end and pulling it out of its socket (circled in red on the image to the left).
    • Additionally, the black wire highlighted in the square yellow box in the image to the left is taped onto the main board. This tape may be safely removed to give the wire more slack when separating the two halves of the boombox.
    • The power supply and antenna are located on the bottom half of the boombox while the headphone jack, function buttons and lcd screen are located on the top half.
    Ask FixBot
  4. Memorex 2Xtreme MP3830-01 Function Buttons Replacement, Locating the Circuit Board: step 4, image 1 of 1
    • The circuit board that contains the function buttons is located to the left of the boombox's main circuit board.
    • The main circuit board can optionally be removed (covered in other guides0 if it is too difficult to access the board containing the function buttons. However, we do not recommend doing this if it is not necessary since removing the main board is difficult.
    Ask FixBot
  5. Memorex 2Xtreme MP3830-01 Function Buttons Replacement: step 5, image 1 of 1
    • There are a total of four screws holding the function button circuit board onto the outer shell of the boombox.
    • Remove the four screws using a Phillips-head screwdriver and gently pull the circuit board up from the case.
    • Be careful not to break or damage the white wires connecting the function button circuit board to the main board.
    Ask FixBot
  6. Memorex 2Xtreme MP3830-01 Function Buttons Replacement: step 6, image 1 of 1
    • Remove the circuit board from the case without disconnecting the wires.
    • Flip the circuit board over so that the tan side is up (instead of the green side).
    • There are a total of six function buttons on the board which correspond to the function buttons on the outer shell. Locate the button on this baord that you intend to replace.
    • The buttons on this board all have white labels near them. This can help you identify which button to replace.
    Ask FixBot
  7. Memorex 2Xtreme MP3830-01 Function Buttons Replacement: step 7, image 1 of 1
    • Once the button to replace has been identified, flip the board over so that the green side is face up.
    • Position the circuit board so that it will be easy to use a soldering iron on.
    • Heat the connections of the button to replace with the soldering iron until all solder is removed. Then pull the button from the board.
    • Replace the button with a new, working button and apply new solder with the soldering iron to the connections in back.
    • Each button has a total of four connectors to remove/solder.
    • Ensure that the old solder is completely removed from the board to prevent any electrical shorts when the new button is connected.
    Ask FixBot
Meghan
579 Reputation
5 Guides authored
UMass Dartmouth, Team 2-4, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-4, Duarte Fall 2014
UMASSD-DUARTE-F14S2G4
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 573
