Melitta Caffeo Barista T opening
  1. Melitta Caffeo Barista T opening, Preparation: step 1, image 1 of 1
    • Never forget: Remove the cable from the powerplug
    • Remove all the parts
    Ask FixBot
  2. Melitta Caffeo Barista T opening, Remove the backside: step 2, image 1 of 2 Melitta Caffeo Barista T opening, Remove the backside: step 2, image 2 of 2
    • The backside is fixed with seven Torx T10 screws. Unscrew them
    • Get the Backside of. It should be a bit stuck.
    Ask FixBot
  3. Melitta Caffeo Barista T opening, Remove the powder compartment lid: step 3, image 1 of 3 Melitta Caffeo Barista T opening, Remove the powder compartment lid: step 3, image 2 of 3 Melitta Caffeo Barista T opening, Remove the powder compartment lid: step 3, image 3 of 3
    • Pull the powder compartment up.
    • Pull one of the sides of the Powder compartment out of the hinge and loosen the lid.
    • Remove the powder compartment
    Ask FixBot
  4. Melitta Caffeo Barista T opening, Loosen the upper housing part: step 4, image 1 of 3 Melitta Caffeo Barista T opening, Loosen the upper housing part: step 4, image 2 of 3 Melitta Caffeo Barista T opening, Loosen the upper housing part: step 4, image 3 of 3
    • In the powder compartment, you should see a rubber cover. Loosen the rubber cover with the appropriate tools.
    • There should also be a Torx T10 screw. Unscrew it
    Ask FixBot
  5. Melitta Caffeo Barista T opening, loosening the Upper housing part: step 5, image 1 of 2 Melitta Caffeo Barista T opening, loosening the Upper housing part: step 5, image 2 of 2
    • The upper cover with the brewing unit is held up from three clamps. These can be reached through a slit.
    • Press these clams with a flat scredriver in and pull the upper cover up, until the clamps loosen.
    Ask FixBot
  6. Melitta Caffeo Barista T opening, Removal of the upper case: step 6, image 1 of 3 Melitta Caffeo Barista T opening, Removal of the upper case: step 6, image 2 of 3 Melitta Caffeo Barista T opening, Removal of the upper case: step 6, image 3 of 3
    • On the side that has a a watertank you can find 2 other clamps
    • Press these clamps with a flat scredriver in and pull the cover up until they loosen
    • Lift the upper cover and the backside up, hook it on the front edge and remove them
    Ask FixBot
  7. Melitta Caffeo Barista T opening, Removal of the side panel: step 7, image 1 of 2 Melitta Caffeo Barista T opening, Removal of the side panel: step 7, image 2 of 2
    • Push the right and the left side panel back, then pull the lower edge out and pull the side panel out.
    • This could be a bit stuck
    • On the side panel with the watertank, there should be a supply hose attached to a cable that connects the water-level sensore. loosen them
    • Hint: the side panel doesn't have to be removed completely for each repair.
    Ask FixBot
Work through the steps in reverse order, to rebuild your machine.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
335,961 Reputation
311 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
38 Members
1,688 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 47
Past 30 Days: 213
All Time: 7,236
