Up to 20% off select tools
Meizu MX3 Screen Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
113
All Time:
4,336
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Screen replacement (without frame)
    1. Meizu MX3 Screen Replacement, Screen: step 1, image 1 of 1
      • Remove the back panel, and unscrew everything to remove the second back panel. Some screw are longer than other. But I mixed them without issue. Here I saw the solution for the network issue: the little contacts between motherboard and screen were bended.
      • I removed the battery, but I think it's not mandatory. If you do, be careful, it's very well glued, and there is some wires behind.
      Ask FixBot
    2. Meizu MX3 Screen Replacement: step 2, image 1 of 1
      • Unplug all the connectors to the motherboard, included the two antennas The small flat ribbon in the corner is a little tricky, you have to switch the black part of the connector, not the white one like some other similar I saw before.
      Ask FixBot
    3. Meizu MX3 Screen Replacement: step 3, image 1 of 1
      • Remove the jack connector, removes the lasts screws (mark the placement for later)
      • Remove the motherboard, starting by the upper part: There is a last connector to unplug at the bottom, behind.
      Ask FixBot
    4. Meizu MX3 Screen Replacement: step 4, image 1 of 2 Meizu MX3 Screen Replacement: step 4, image 2 of 2
      • Now, remove the old screen. It's glued, try to lift a corner, then with a plastic tool, unglue everything.
      • Clean the glue inside the metal part.
      Ask FixBot
    5. Meizu MX3 Screen Replacement: step 5, image 1 of 1
      • Put some adhesive (or some glue?) I used thin double-sided tape I had cut the right shape. the side of the screen are less than 1mm wide, it's hard to do here...
      Ask FixBot
      • Put the screen in the frame, and put everything back in place.
      • Voila!
      Ask FixBot
5 other people completed this guide.
Author
with
Feyris
144 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 113
All Time: 4,336
