Up to 20% off select tools
Mechanical Pencil Spring Replacement
Views: 15K
View statistics:
Past 24 Hours:
7
Past 7 Days:
78
Past 30 Days:
377
All Time:
15,321
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your mechanical pencil no longer produces lead - either no lead is produced from pressing the dispenser, or the dispenser cannot be compressed - this guide can help you restore function. An Xtra Strong Mechanical Pencil is used in this guide, although the process is similar for other brands. This fix targets the replacement of broken or jammed springs, which anyone of any technical skill level can accomplish. Your mechanical pencil will need to be disassembled, the old spring removed and replaced, and then reassembled. No special considerations or tools are required.
    1. Mechanical Pencil Spring Replacement, Spring: step 1, image 1 of 2 Mechanical Pencil Spring Replacement, Spring: step 1, image 2 of 2
      • Remove the eraser from the mechanical pencil.
      • Removing the eraser may be difficult if the eraser is too short.
      Ask FixBot
    2. Mechanical Pencil Spring Replacement: step 2, image 1 of 1
      • Remove the graphite lead from the pencil.
      • Make sure to give the pencil a few clicks to get any remaining lead out of the front of the pencil.
      Ask FixBot
    3. Mechanical Pencil Spring Replacement: step 3, image 1 of 2 Mechanical Pencil Spring Replacement: step 3, image 2 of 2
      • Unscrew the cone/cap from the pencil.
      • You may be able to unscrew the cap. Some require you to pull it off using force. Procedures vary based on each pencil.
      Ask FixBot
    4. Mechanical Pencil Spring Replacement: step 4, image 1 of 2 Mechanical Pencil Spring Replacement: step 4, image 2 of 2
      • Depress the shaft into the sleeve.
      Ask FixBot
    5. Mechanical Pencil Spring Replacement: step 5, image 1 of 3 Mechanical Pencil Spring Replacement: step 5, image 2 of 3 Mechanical Pencil Spring Replacement: step 5, image 3 of 3
      • While keeping the shaft depressed, slide the gold dispenser ring back into the sleeve to expose the dispenser.
      Ask FixBot
    6. Mechanical Pencil Spring Replacement: step 6, image 1 of 3 Mechanical Pencil Spring Replacement: step 6, image 2 of 3 Mechanical Pencil Spring Replacement: step 6, image 3 of 3
      • Use pliers to grasp the dispenser perpendicular to the open split.
      • Apply pressure and pull the dispenser straight out from the shaft and sleeve. This may be difficult.
      • If the dispenser is grasped incorrectly it could cause damage.
      • Be careful not to lose or bend the dispenser ring in the process. It is small and fragile.
      Ask FixBot
    7. Mechanical Pencil Spring Replacement: step 7, image 1 of 1
      • Remove the shaft and spring from the sleeve.
      • The spring is small. Be sure not to lose it so it can be discarded properly.
      Ask FixBot
    8. Mechanical Pencil Spring Replacement: step 8, image 1 of 2 Mechanical Pencil Spring Replacement: step 8, image 2 of 2
      • Place the dispenser and dispenser ring into the sleeve in the order it was removed.
      • The flange or widest portion of the dispenser ring will be closest to the opening of the dispenser.
      • You will need to hold it in place for the next step.
      Ask FixBot
    9. Mechanical Pencil Spring Replacement: step 9, image 1 of 2 Mechanical Pencil Spring Replacement: step 9, image 2 of 2
      • Place the new spring and old shaft into the sleeve in the order it was taken out.
      • The spring is small. Be sure not to lose it.
      Ask FixBot
    10. Mechanical Pencil Spring Replacement: step 10, image 1 of 3 Mechanical Pencil Spring Replacement: step 10, image 2 of 3 Mechanical Pencil Spring Replacement: step 10, image 3 of 3
      • Using your thumb or a hard surface pressed against the dispenser, push the shaft into the dispenser.
      • There should be an audible clicking sound.
      • Pushing the dispenser into the shaft from the front could cause damage to dispenser and dispenser ring.
      Ask FixBot
To reassemble your device, follow steps 1 - 3 of these instructions in reverse order.
5 other people completed this guide.
Author
with
Cassie Kohlhepp
196 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 377
All Time: 15,321
