Mechanical Pencil Lead Replacement
View statistics:
Past 24 Hours:
12
Past 7 Days:
63
Past 30 Days:
129
All Time:
129
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 seconds
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
A simple guide on how to replace the lead in a mechanical pencil. This guide uses the BIC Xtra Smooth Mechanical Pencil for the example images.
    1. Mechanical Pencil Lead Replacement, Get Your Mechanical Pencil: step 1, image 1 of 1
      • Retrieve your mechanical pencil from your pencil case, the floor, or wherever you store it.
      Ask FixBot
    2. Mechanical Pencil Lead Replacement, Remove The Eraser: step 2, image 1 of 1
      • Use your desired tool to remove the eraser from your pencil. This can be done with tweezers, your fingernails, etc.
      Ask FixBot
    3. Mechanical Pencil Lead Replacement, Check Compatible Lead Diameter: step 3, image 1 of 1
      • There should be a label somewhere on your pencil saying the compatible lead diameter. This is normally located on the clip. In this example, the pencil uses 0.7mm lead, which is the most common diameter.
      • Cross reference the label to your pencil lead container to make sure the lead is compatible.
      Ask FixBot
    4. Mechanical Pencil Lead Replacement, Retrieve Replacement Lead From Container: step 4, image 1 of 1
      • Open your container of compatible replacement lead and pour out 1-3 sticks of replacement lead onto your hand.
      Ask FixBot
    5. Mechanical Pencil Lead Replacement, Put Replacement Lead Into Pencil: step 5, image 1 of 1
      • While holding your pencil tip-down, put the sticks of lead into the hole located under where the eraser goes.
      Ask FixBot
    6. Mechanical Pencil Lead Replacement, Put The Eraser Back On: step 6, image 1 of 1
      • Put the eraser back into the eraser hole. Make sure none of the pencil lead is sticking out past the top of the barrel before you do this.
      • If the pencil lead is sticking out past the top of the barrel, try shaking the pencil or tapping it gently on a flat surface. If this doesn't work, make sure there isn't too much lead inside the barrel.
      Ask FixBot
    7. Mechanical Pencil Lead Replacement, Check If Lead Is Working: step 7, image 1 of 1
      • Push the button to push out the lead (in this example it's located at the top of the pencil) and check the pencil tip to see if the lead is coming out correctly.
      • If the lead is NOT coming out correctly, or slipping when trying to write, the lead may not be compatible, or may be too short.
      Ask FixBot
    8. Mechanical Pencil Lead Replacement, Finished!: step 8, image 1 of 1
      • Your mechanical pencil should now be usable again! :D
      Ask FixBot
You should now be able to use your mechanical pencil for a little while longer! :]
kookyroni
2 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 63
Past 30 Days: 129
All Time: 129
