Up to 20% off select tools
Maze Speed SSB-508 Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
7
Past 7 Days:
20
Past 30 Days:
71
All Time:
1,662
Comments: 13
13 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Very difficult
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide will show the process of replacing the glass screen of a Maze Speed phone. You will need a plastic opening tool, tweezers, iOpener, Phillips #00 Screwdriver, and soldering equipment. Soldering experience is beneficial in order to avoid damaging the phone’s other components. If the glass screen is cracked or shattered, you need to take extra precaution not to cut yourself.
    1. Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 1 of 3 Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 2 of 3 Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 3 of 3
      • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
      Ask FixBot
    2. Maze Speed SSB-508 Screen Replacement: step 2, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 2, image 2 of 2
      • Remove fifteen 2mm Phillips #00 screws.
      Ask FixBot
    3. Maze Speed SSB-508 Screen Replacement: step 3, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 3, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 3, image 3 of 3
      • Lift the plastic opening tool up at the bottom left corner to create the gap.
      • Repeat this through all corners to remove the internal casing.
      Ask FixBot
    4. Maze Speed SSB-508 Screen Replacement: step 4, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 4, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 4, image 3 of 3
      • Unscrew the 2mm screw at the bottom right of the motherboard.
      • Remove the internal antenna casing from the motherboard.
      Ask FixBot
    5. Maze Speed SSB-508 Screen Replacement: step 5, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 5, image 2 of 2
      • Unplug the speaker at the top of the motherboard.
      Ask FixBot
    6. Maze Speed SSB-508 Screen Replacement: step 6, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 6, image 2 of 2
      • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
      Ask FixBot
    7. Maze Speed SSB-508 Screen Replacement: step 7, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 7, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
      • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
      • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
      Ask FixBot
    8. Maze Speed SSB-508 Screen Replacement: step 8, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 8, image 2 of 2
      • At this point, the motherboard should be able to be lifted up from the bottom.
      • Use the tweezers to dislodge the speaker.
      • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
      • Using a soldering tool, desolder the cable from the back of the motherboard.
      Ask FixBot
    9. Maze Speed SSB-508 Screen Replacement: step 9, image 1 of 1
      • Remove the motherboard from the back.
      Ask FixBot
    1. Maze Speed SSB-508 Screen Replacement, Screen: step 10, image 1 of 2 Maze Speed SSB-508 Screen Replacement, Screen: step 10, image 2 of 2
      • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
      Ask FixBot
    2. Maze Speed SSB-508 Screen Replacement: step 11, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 11, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 11, image 3 of 3
      • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
      • Gently lift the glass screen and remove from the frame.
      Ask FixBot
    3. Maze Speed SSB-508 Screen Replacement: step 12, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 12, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 12, image 3 of 3
      • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
      Ask FixBot
    4. Maze Speed SSB-508 Screen Replacement: step 13, image 1 of 1
      • Move the connecting wire through the hole at the top frame.
      • Then, remove the glass screen and replace with the new one.
      Ask FixBot
To reassemble your device, follow these instructions carefully in reverse order.
Author
with
Jun Soo Kim
385 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 71
All Time: 1,662
