Maylong MN-1000P Motherboard Replacement
    1. Maylong MN-1000P Motherboard Replacement, Bottom Cover: step 1, image 1 of 1
      • Place the netbook top down, with the opening of the netbook facing you.
      Ask FixBot
    2. Maylong MN-1000P Motherboard Replacement: step 2, image 1 of 1
      • Remove the six 6mm Phillips #00 screws from the netbook.
      Ask FixBot
    3. Maylong MN-1000P Motherboard Replacement: step 3, image 1 of 3 Maylong MN-1000P Motherboard Replacement: step 3, image 2 of 3 Maylong MN-1000P Motherboard Replacement: step 3, image 3 of 3
      • Remove the sticker in the middle of the netbook.
      • Remove the middle 6mm Phillips #00 screw.
      Ask FixBot
    4. Maylong MN-1000P Motherboard Replacement: step 4, image 1 of 1
      • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
      Ask FixBot
    5. Maylong MN-1000P Motherboard Replacement: step 5, image 1 of 1
      • Remove the bottom of the netbook by lifting the corners.
      Ask FixBot
    1. Maylong MN-1000P Motherboard Replacement, Battery: step 6, image 1 of 2 Maylong MN-1000P Motherboard Replacement, Battery: step 6, image 2 of 2
      • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
      Ask FixBot
    1. Maylong MN-1000P Motherboard Replacement, Screen: step 7, image 1 of 1
      • Remove the six 6mm Phillips #00 screws from both sides of the netbook.
      Ask FixBot
    2. Maylong MN-1000P Motherboard Replacement: step 8, image 1 of 2 Maylong MN-1000P Motherboard Replacement: step 8, image 2 of 2
      • Pull the top of the computer and the back side of the computer away from each other until they are detached.
      • Flip the entire computer over so you can see both the screen and keyboard.
      Ask FixBot
    3. Maylong MN-1000P Motherboard Replacement: step 9, image 1 of 2 Maylong MN-1000P Motherboard Replacement: step 9, image 2 of 2
      • Remove all the black circular pads from around the screen.
      • Remove all 6mm Phillips #00 screws from around the screen bezel.
      Ask FixBot
    4. Maylong MN-1000P Motherboard Replacement: step 10, image 1 of 1
      • Using a plastic opening tool, pry off the screen bezel.
      • After detaching the screen bezel, pull up on the bezel near the hinge area.
      Ask FixBot
    5. Maylong MN-1000P Motherboard Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
      Ask FixBot
    6. Maylong MN-1000P Motherboard Replacement: step 12, image 1 of 1
      • Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
      Ask FixBot
    7. Maylong MN-1000P Motherboard Replacement: step 13, image 1 of 3 Maylong MN-1000P Motherboard Replacement: step 13, image 2 of 3 Maylong MN-1000P Motherboard Replacement: step 13, image 3 of 3
      • Detach the wide yellow ribbon cable connected to the screen from the computer.
      Ask FixBot
    8. Maylong MN-1000P Motherboard Replacement: step 14, image 1 of 2 Maylong MN-1000P Motherboard Replacement: step 14, image 2 of 2
      • Flip the computer over.
      • Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
      Ask FixBot
    9. Maylong MN-1000P Motherboard Replacement: step 15, image 1 of 3 Maylong MN-1000P Motherboard Replacement: step 15, image 2 of 3 Maylong MN-1000P Motherboard Replacement: step 15, image 3 of 3
      • Remove the black tape holding down the red, green, black, and white intertwined wires.
      • Remove the screen.
      Ask FixBot
    1. Maylong MN-1000P Motherboard Replacement, Motherboard: step 16, image 1 of 1
      • Remove the six 6mm Phillips #00 screws from the motherboard.
      Ask FixBot
    2. Maylong MN-1000P Motherboard Replacement: step 17, image 1 of 1
      • Remove the two 6mm silver screws from the small circuit board connected to the motherboard by the red and black wires.
      Ask FixBot
    3. Maylong MN-1000P Motherboard Replacement: step 18, image 1 of 1
      • Remove the two small black speakers on the corners connected to the motherboard by the black and red wires.
      Ask FixBot
    4. Maylong MN-1000P Motherboard Replacement: step 19, image 1 of 1
      • Disconnect the black connectors from the motherboard by pulling on the white ribbon cable.
      Ask FixBot
    5. Maylong MN-1000P Motherboard Replacement: step 20, image 1 of 2 Maylong MN-1000P Motherboard Replacement: step 20, image 2 of 2
      • Remove the black covered wire connected to the motherboard by pulling the white ribbon cable away from the motherboard.
      Ask FixBot
    6. Maylong MN-1000P Motherboard Replacement: step 21, image 1 of 1
      • Using a spudger, remove the gold cylinder out of the indent at the bottom of the computer.
      Ask FixBot
    7. Maylong MN-1000P Motherboard Replacement: step 22, image 1 of 2 Maylong MN-1000P Motherboard Replacement: step 22, image 2 of 2
      • Lift the motherboard up.
      • Remove the motherboard by detaching the clear tape from underneath the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 368
