Maylong MN-1000P Bottom Cover Replacement
    1. Maylong MN-1000P Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
      • Place the netbook top down, with the opening of the netbook facing you.
      Ask FixBot
    2. Maylong MN-1000P Bottom Cover Replacement: step 2, image 1 of 1
      • Remove the six 6mm Phillips #00 screws from the netbook.
      Ask FixBot
    3. Maylong MN-1000P Bottom Cover Replacement: step 3, image 1 of 3 Maylong MN-1000P Bottom Cover Replacement: step 3, image 2 of 3 Maylong MN-1000P Bottom Cover Replacement: step 3, image 3 of 3
      • Remove the sticker in the middle of the netbook.
      • Remove the middle 6mm Phillips #00 screw.
      Ask FixBot
    4. Maylong MN-1000P Bottom Cover Replacement: step 4, image 1 of 1
      • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
      Ask FixBot
    5. Maylong MN-1000P Bottom Cover Replacement: step 5, image 1 of 1
      • Remove the bottom of the netbook by lifting the corners.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kristen Gismondi
108,804 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 208
