Insert plastic opening tool at the corner of the screen, in between the back case and the front.
Volume buttons will fall out during removal.
When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
Tool used on this step:Tweezers$4.99
With the tweezers, grab onto the gray part of the ribbon clamps and pull away from the ribbons.
Once the ribbons are unclamped, they are able to slide out.
2 other people completed this guide.
